plug-in as an input is greyed out?
Hi, Im trying to use BFD in pro tools and route it into multi channels but for some reason when I create a stereo audio track and then go to input the only thing there is inputs and busses. the plugin section is there but it seems to be greyed out. Anyone help?
------------------------- OSX 10.5.8 Pro Tools 8.0 HD MAC PRO Dual 3.2GHz Quad- Core 8 GB RAM EXTERNAL OWC FIREWIRE 800 Drives 2 x Digi 192 i/o 24 ins 24 outs |
Re: plug-in as an input is greyed out?
There are 2 versions of BFD in your plugs folder! if you want to use the seperate outs, you need to use the one called "BFD ALL" not the one called BFD STEREO. then the individual outputs will show in the I/O on audio tracks and aux tracks. Insert into a stereo audio track. also make sure you have the latest version v 1.0.10.21 Chris
I have the same problem, can someone explain to me what to do? I want to load Maschine as a VST in PT9.
Instrument Input greyed out | lexaudio | macOS | 2 | 10-22-2013 04:17 AM |
Input>Plug In Greyed Out | typhy | macOS | 1 | 08-15-2011 06:17 PM |
Input monitoring greyed out on auxes | Studio Studio | Pro Tools TDM Systems (Mac) | 1 | 04-14-2009 01:11 AM |
Input Selections Greyed Out | GJH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-21-2005 03:58 PM |
Midi Input Enable greyed out in 6.7 (Digi002rack) | pugman84 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-26-2004 12:24 PM |
