Old 07-16-2018, 12:54 PM
djh108 djh108 is offline
Default What genius can help decipher delivery specs?
I primarily do music production, but occasionally get gigs that include post mixing. I'm mixing a cable TV show this week and I'm having trouble understanding the delivery specs, hoping those wiser than I can enlighten me. Here they are the specs, verbatim:
" 2.1.8 Mixing
Episodes that are delivered with poorly mixed audio will be rejected.
  • § Average audio levels should be recorded at -12dB, including whispered voices.
  • § Transient audio, like gunshots, are the only exception: they can peak up to -8dB.
  • § Absolutely no audio should rise above -8dB, ever. Any audio above -8dB will likely be distorted by
    the compression added by our carriers.
  • § Audio must be mixed on two channels in stereo. Stereo audio must be fully mono compatible. The
    audio channels must be in proper phase.
  • § Program audio must reflect 1 kHz reference tone level set to -12dB. Audio levels must be consistent
    throughout the program with norms averaging -12dB
    NOTE: Full Mono compatibility means that when the left and right stereo channels are actively combined to mono, there is no discernible change in audio level or fidelity
    Summary of the 3 key audio levels you should pay attention to:
    • § -12 dB: reference 1kHz tone, normal audio level – this is where most audio will be (including whispering).
    • § -8 dB: maximum peaks; no audio should ever go above this level.
    • § -20 dB: minimum audio level. No audio should fall below this level, as it will be inaudible on a
      viewer’s television.
Sooo...I guess I'm to assume their values, such as their overall avrage of -12db is an RMS value (or LUFS)? Isn't that crazy hot for broadcast? And then they say nothing can peak above -8db...seems to me that ratio is going to compress the living daylights out of the material to have an average of -12 and no peaks above -8. What am I missing here??
Thanks folks!
Old 07-16-2018, 04:36 PM
its2loud its2loud is offline
Default Re: What genius can help decipher delivery specs?
Time to call or email someone at the network and get it straightened out.
That's what I would do. Most delivery specs are wrong or outdated. That has been my experience.
Old 07-16-2018, 05:16 PM
minister's Avatar
minister minister is offline
These look like standard PEAK values, NOT RMS or LKFS. These look old skool. But, pretty simple.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 07-16-2018, 06:25 PM
philper philper is offline
And you are going to be making a mighty compressed mix, mon ami.
Old 07-17-2018, 12:58 AM
papalou papalou is offline
These specs are crazy.
Lack of precision ("average" ? RMS, LUFS, LKFS ???), and a compressed signal that'll give headache in seconds.
Old 07-17-2018, 10:45 AM
tom_lowe tom_lowe is offline
Anything below -20dB won't be audible, well assuming they mean -20 dBFS that is insane, I mean who wants backgrounds or quiet parts that high.
Awful spec.
Old 07-17-2018, 02:12 PM
TrentWilliams TrentWilliams is offline
Originally Posted by tom_lowe View Post
Awful spec.
+1
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 07-18-2018, 06:24 AM
Originally Posted by djh108 View Post
" 2.1.8 Mixing
Thanks folks!
you don't need a genius to decipher them, you need a blithering moron to make sense of it as they were clearly written by one.
Old 07-18-2018, 11:05 AM
Thanks so much for jumping in, guys. My email notifications for this thread aren't coming for some reason, so I didn't realize these responses were here until just now.
I actually tried that yesterday, wasn't a tremendous amount of help as we were clearly speaking different languages, but my initial guess was somewhat affirmed by the confusing conversation I had, which is basically this...
So my game plan is to just do a balanced mix and use those peak values as my ceiling. The network contact said its rare to have a mix rejected, and I got the sense his motivation for writing things that way simply to avoid getting mixes from novices that are jacked and limited out to wazoo (which, ironically, is exactly what those specs would create if taken literally).
That said, sounds like you've seen similar specs from yesteryear, Minister. Wondering if there's any advice you'd offer mixing to a situation like that...does indeed sound like its an old skool setup with older gear involved...Sounds like the only loudness control they do is hard limiting the ceiling, but nothing to normalize mixes that average too soft..would you approach it the way I described above if you were in my shoes? Or maybe lean it a little on the compressed side? - thanks so much...
Old 07-18-2018, 11:25 AM
going back a few years to -10 peak specs for most networks, the usual method was to throw a brickwall limiter on all DIA, MX, FX, and FULL MIX Busses.
Regarding the " § -20 dB: minimum audio level. No audio should fall below this level, as it will be inaudible on a
viewer’s television. " spec. I would take this to mean that no spoken dialog should fall below this number. There's no way you're gonna drive up music or BG's to that level without it sounding ridiculous within the content of the show.
The things that really puzzles me is the -12dB reference 1K tone spec. I think they just mean they want all the dialog sitting around -12. Which is about where it would sit if you were mixing to around -24LKFS.
Again, too much is open to interpretation and guessing. These specs are horrible. Good luck
HTML code is On
Referencing DVD's and delivery specs rabinrocks Post - Surround - Video 2 01-24-2011 08:35 PM
Help! TV delivery specs question rabinrocks Post - Surround - Video 6 01-22-2011 10:13 PM
please help me decipher these delivery specs (UK, I think)? jmattchan Post - Surround - Video 6 01-06-2011 07:02 AM
European Delivery Specs EarHole Post - Surround - Video 1 08-19-2010 12:09 PM
Dolby delivery specs D'Animation Post - Surround - Video 5 09-10-2009 01:42 AM
