Old 01-27-2015, 01:29 PM
adavisxpn adavisxpn is offline
Default S3 + EUCON + Yosemite
Hello all.
First, I do understand that the s3 is not fully blessed for 10.10 yet, hence why I am posting here as opposed to speaking directly to Avid.
I have the s3 connected and configured. It's working perfectly with Pro Tools as a control surface.
The issue that I am running into is that the S3 seems to lock out the other Ethernet adapters on the Mac Pro. No matter which Ethernet port I use (onboard 1, onboard 2 or an Ethernet to thunderbolt adapter). Once the S3 is connected the other ethernet adapters show "cable unplugged". I can get the thunderbolt -> ethernet adapter to come back by unplugging it and disabling/enabling the adapter.
Has anyone else run into this issue?
Old 01-27-2015, 05:59 PM
Norrie's Avatar
Norrie Norrie is offline
Default Re: S3 + EUCON + Yosemite
Have you tried using a network switch ?
I don't suffer from insanity -- I enjoy every minute of it !
Avid S3
Artist Transport
Pro Tools HD 12
UAD Apollo 8P
Audient ASP 880
Mac Pro TrashCan
3.5 GHz 6-Core Intel Xeon E5, 32GB ram
Adams A77x
UAD Quad Thunderbolt Satellite
Old 01-28-2015, 07:38 AM
I have not. The issue with using a switch is that the two other networks that this machine connects to are both static IP networks. I don't see a way to make the s3 use anything except for DHCP unless I missing something.
Unless you are suggesting that I use a switch and only put the Mac Pro and the S3 on it using DHCP? I'll give that a shot.
Old 01-29-2015, 08:53 AM
Update:
I tried using both a managed and unmanaged switch and no luck. It seems like now matter how I connect the S3 to the Mac Pro as soon as EUControl connects to the S3 it kills the other ethernet connections.
The work around for now is to use Thunderbolt -> Ethernet adapters for the other networks (everything but the S3). By disabling the connection, unplugging the adapter, plugging the adapter back in and then re-enabling the connection I can get the connections to come back.
Kind of a drag but I do get the the S3 is not supported on 10.10 at this time. Hopefully Avid gets an update out soon.
Old 02-09-2015, 06:01 AM
Update in case someone has the same issue and runs across this thread - everything has sort of magically started working correctly. I don't know if maybe it was the 20th reboot that finally did it but everything is playing nicely now, no more network issues.
The S3 seems to be a little picky about how things are booted up, how long after a complete boot you wait until starting the EUControl software, etc but so far so good.
PT9 Yosemite paldry Pro Tools 9 2 12-27-2014 08:40 AM
Eucon compatibility with OS X Yosemite Yore Artist Series 5 11-21-2014 05:37 AM
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
