Old 03-24-2004, 04:02 PM
DC11 DC11 is offline
Default DSP Card and Farm Card: How much more Power?
I've got a Mix + system and would like to add more power for plug-ins. Is it worth getting another farm card, or will a DSP Farm card be enough. I can't find any info as to how much power you get with these cards. I figure it's easier for me to get a couple of DSP's cause I could get a couple now, the a couple later.
Old 03-24-2004, 05:18 PM
Lee Blaske Lee Blaske is offline
Default Re: DSP Card and Farm Card: How much more Power?
Back when they were being marketed, I seem to recall that the Mix Farm was said to be approximately equal to three DSP Farm Cards. In practice, it wasn't as clear cut, because not all of the Mix Farm chips could run all of the plug-ins.
Lee Blaske
Old 03-24-2004, 06:52 PM
Chief Technician's Avatar
MIX and DSP Farm RAM explanation.
This card only has one type of RAM for all four chips (MIX cards have six chips and three types of RAM). If you've got plugs that will run on this card, then it frees up MIX chips to run the plugs that the DSP Farm cannot.
The DSP Farm is incompatible with the G5 (physical characteristics).
Old 03-25-2004, 07:35 PM
Thanks alot. That helped alot. I've foundeded my solution.
PT Mix - Power Card? Questions - It's a Mix Core labeled Power Card Table Syrup Records Digidesign Hardware & Software 13 12-02-2013 04:30 PM
MIX Farm Power Card *DELETED* Siegfried Meier Pro Tools TDM Systems (Mac) 1 09-16-2005 07:02 PM
32 outs with a d24 card and a mix farm card MOONMAN Pro Tools TDM Systems (Mac) 5 06-07-2005 10:26 AM
processing power QE farm card vs. mix farm card lennox Digidesign Hardware & Software 3 03-03-2003 03:24 PM
Will PTIII IO card work w/o farm card? copywell Pro Tools TDM Systems (Mac) 4 02-14-2001 06:23 AM
