Old 01-21-2003, 11:47 PM
dannepop dannepop is offline
Default Key shortcut for rewind from beginning?
Does anyone know what the Keyboard shortcut for rewind from beginning is?
Danne/
danne
Old 01-22-2003, 12:13 AM
Default Re: Key shortcut for rewind from beginning?
You can't rewind from the beginning.. where could you go.. back to the beginning?
The Enter key on the main keyboard, however, does return you to the top of the session.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-22-2003, 01:47 AM
Dirren Dirren is offline
'twas quite clear that dannepop meant rewind TO the beginning. what a sloppy reply Rogut...
Old 01-22-2003, 01:52 AM
Never played a tune from the top to the bottom.
Perhaps it would be an experience!
Then the hips would start to sway at the end of the song!
Thanks for the hip, oops the I meant the tip.
"Some can and some can΄t"
danne
Old 01-22-2003, 02:06 AM
Actually Dirren.. that was tongue in cheek.. I wasn't 100% sure if he meant to the top of the session - or the begining of his song (which would require markers)... However, my reply also included the answer.. if I was trying to be a jerk - I wouldn't have included that.
Rail
Platinum Samples
Old 01-22-2003, 05:39 AM
gargoyle gargoyle is offline
While we are at it, this one has always baffled me:
What is the consolidate selection shortcut, I see it right there in the menu but I can't make it work, the up arrow doesn't work (same arrow as in insert silence) and what is the other symbol, looks like a merging highway symbol.
Thanks
Sean
Old 01-22-2003, 06:14 AM
Ben Jenssen's Avatar
<font size="2" face="Verdana, Arial">That’s the "option"-key, its between the cntrl and command keys.
Old 01-22-2003, 07:37 AM
dkrz dkrz is offline
<font size="2" face="Verdana, Arial">If you deselect "Timeline insertion follows play back." under Setups menu--> Preferences--> Operation; your cursor will remain in place and PT will playback from that location when you hit stop. In other words, it won't playback from where it left off, only from where you place the cursor. Sort of like auto rewind from where ever you started playback from.
You should get used to using markers., it has some powerful recall features that many people overlook. Check out the manual for some cool Marker tricks.
dk
www.dpkmusic.net
Old 01-22-2003, 09:57 AM
vlad vlad is offline
"the up arrow doesn't work"
Hey Gargoyle, the "up" symbol is shift. The Merging highways are option keys.
-Martin
Rewind on stop. spankenstein Pro Tools M-Powered (Win) 2 10-12-2006 07:52 PM
rewind!! WorkingEngineer Pro Tools TDM Systems (Mac) 16 01-19-2006 03:17 PM
Rewind to 00:00:00 studiotony 001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-17-2003 05:55 PM
FF and rewind shortcut TravisDRS Pro Tools TDM Systems (Mac) 0 03-15-2003 09:16 PM
Auto rewind Goddony 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-15-2001 12:44 AM
