CPU problem (ever since ....)
What's up,
I formatted my laptop and installed pro tools again and ever since I formatted I've been getting CPU errors. I'm opening mixed sessions that I've opened before and I get that error. I can't even bounce the song down ...... I've never had this problem. Any ideas what it could be? I think I had SP1 for Vista before I formatted but I don't now. Could that be it? Should I do some updates for my VAIO? thanks
MBox 2 Mini Pro Tools 7.4 - MPTK Sony VAIO VGN-NR120E Windows Vista Home Premium |
Re: CPU problem (ever since ....)
what are the error messages of codes? without them we'd be stabbing in the dark at your problem. also what version of PT?
Pro Tools 7.4 cs 9
Error 9128 (Is there a way I could disable the volume knobs from moving up and down while bounce is in progress?)
If you post a Sandra or PC Wizard report, that would be very helpful. See the Help Us Help You and Genberal Troubleshooting Stickies for instructions. We don't have any information to go on. Cheers,
PC Wizard 2008 Version 1.871
------------------------------------------------------------------------------------------ Operating System: Windows Vista (TM) Home Premium Home Edition 6.00.6000 Report Date: Sunday 31 May 2009 at 17:31 ------------------------------------------------------------------------------------------ <<< System Summary >>> > Mainboard : Sony Corporation VAIO > Chipset : Intel GM965 > Processor : Intel Pentium T2310 @ 1466 MHz > Physical Memory : 1024 MB (2 x 512 DDR2-SDRAM ) > Video Card : Mobile Intel(R) 965 Express Chipset Family > Hard Disk : Hitachi (160 GB) > DVD-Rom Drive : SONY DVD RW AW-G540A ATA Device > Monitor Type : 142 inches > Network Card : Marvell Semiconductor (Was: Galileo Technology Ltd) Yukon 88E8039 PCI-E Fast Ethernet Controller > Network Card : Atheros Communications Inc AR5006 family 802.11abg Wireless NIC > Operating System : Windows Vista (TM) Home Premium Home Edition 6.00.6000 > DirectX : Version 10.00 > Windows Performance Index : 3.1 ------------------------------------------------------------------------------------------ ***** End of report *****
well the first thing that jumps out at me is that you only have 1 drive. protools needs 2 seperate drives - 1 to record to and 1 system (for storing program and plugs)
digi say themselves that using the same drive for both can cause detremental issues. |
Nah I have an external hard drive.
Is it a firewire drive? USB external drives are not recommended or approved/supported by Digidesign. Does it have one of the approved Oxford chipsets in the enclosure? Does the firewire card in the computer have an approved TI chipset?
Cheers,
Yea I use firewire.
There used to be so take a look thru the preferences pages(I would but I am not at the studio right now). I think it may have been called "silent mode" or "silent mix". This assumes you are referring to the actual faders on your control surface. If by chance you meant the virtual faders in the edit window, you can disable automation(hold the Alt key while you turn Auto off on any track and all will be turned off).
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? | Priz | Windows | 1 | 09-25-2011 12:51 PM |
ELS Vocoder plugin problem and fresh Windows 7 install problem | Thorpey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-09-2011 05:03 AM |
Repeatable problem MP 7.4 upgraded to 8, ProFire 2626 problem | tylerparkinson | Pro Tools M-Powered (Mac) | 0 | 08-21-2009 02:20 PM |
digi 002/7.4 installation problem/not recordable volume problem | fifthflaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2008 01:28 PM |
Audio Regions Display Problem & Grabber Problem | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2002 04:08 AM |
