Whys do my AS settings sound different...
than whe they are used as insert plugins? I have this LA-2A setting that sounds great as a plugin...so when I remove it from the insert and then call it up in AudioSuite it sounds different, and it's louder.
Anyone else experience this with Audio Suite? Also how do ya'll apply AS? Do you remove the plugin or do you just bypass it so you can compare, and then remove it after the AS track is in use. I think that if you keep the plugin inserted and don't bypass you get a double dose of the affect when you then apply the AS version, right? What's your approach? Steve
My studio... http://www.deadriverstudio.com |
Re: Whys do my AS settings sound different...
first i use the rtas version of the plugin on the track and adjust the settings. then i save the pluggin settings. next i select the area i want to process and open up the audiosuite version of the plugin. then open up the saved settings and process. also remember to remove the rtas plugin from the track or it will be like have two identical plugins on the track.
Just to be clear, are we talking about the difference between file-based Audiosuite and real-time Audiosuite?
Hitting "preview" in the file-based plugs will often sound different than inserting a real-time plugin because of level settings (and other processing) within the session that affect the sound you get from RTAS plugs. The "preview" from the file-based plugs is a direct link between the soundfile and your audio outputs, bypassing all the other stuff in the session. It might work better to save your settings from the real-time plug, then open them from the file-based plug and apply them that way....the end result should be the same.
-Mark Mac Pro 8x2.8gHz, 4gb RAM, M-Audio Projectmix I/O, Pro Tools MP 8.0 |
Sounds about the same...I do the set up with the RTAS plugin, save it, remove it from the track, then call up the Audio Suite version, call up the preset, highlight the region and hit preview,
I'll check it out to see that nothing else is affecting the tracks playbacl level in the session. Steve
I disable the plug in once I AS it. (Control + Command + click on plug). Then I can always reactivate it later if need be... or I'll just get rid of it. Like jmark said, I would not trust what you are hearing in the preview of an Audiosuite plug. It;s trying to do too much. Just highlight a samll section and process it to be sure. |
If you test a plugin as rtas first and audiosuite it later, there must be no plugins before it on the track or else there will be a difference in what the rtas and AS are prosessing.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
For Previewing in Audiosuite, Ben's answer is correct... it's just previewing the file with no regards to the RTAS plug-in chain. Also keep in mind that Audiosuite previews through sound manager, which if set to output through the 001, will play back at whatever volume you have set in Sound Manager. Quote:
What I mean is that if you have more than one plugin on a track, and you want to save their presets and print them with AS, you must prosess them in the right order.
Right. [img]images/icons/smile.gif[/img]
At least on the Mac, the AudioSuite preview truncates to 16 bits so the degradation you are hearing IS real. Fortunately the actual processing is done properly without the degradation but it is a pain in the !!!.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
I/O Settings have changed-No sound????? | larsongs | Pro Tools 10 | 29 | 08-27-2019 06:02 PM |
PT 11.1 QT Disabled Sound Settings -BUG? | Bearsonics | Pro Tools 11 | 1 | 01-05-2014 03:35 AM |
Sound settings problem | tjdato | macOS | 0 | 03-28-2013 08:29 PM |
help w/ sound settings using mbox1 + int sound card on G5 | nelsonmay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-25-2007 06:57 AM |
digi 002 6.4 sound settings | Dre aka Producer G | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-10-2005 06:17 AM |
