Old 11-02-2020, 10:49 PM
Ale Ale is offline
Default AAF wirth MFX Audio LOST METADATA
Hi all
I wonder if I do something wrong.
From Mediacomposter i got a folder with mfx audio and an AAF.
First I import (add, Not copy) all audio into session and then I import the AAF.
The problem is that all other Metadata beside the scene/take name is lost.
The weird thing is, that occasionally on some scenes the tracks have the the correct names like Mix, boom. Lav.....
I also tried to import the aaf first and force target format to copy audiofiles to WAV. That does not make a dirrerence.
What am I doing wrong?
Or is the problem on Mediacomposer side?
MFX Problem?
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 11-02-2020, 11:10 PM
Default Re: AAF wirth MFX Audio LOST METADATA
Hm, I simply double click on the AAF select (link where possible) and then relink and point PT to where the media is. No need to add all of it to PT first. I never use 'force' or copy as it breaks our workflow in a larger team where everyone has the original avid media.
Have you looked at the meta-data in the work-space before importing? Maybe there was none in the first place?
Old 11-03-2020, 12:44 AM
Ale Ale is offline
Hi Frank
The metadata is also lost in first place. No Metadata seen
When I import AAF only (no metadata seen) Protools does not see any hidden tracks. Only the audiofiles that are seen in the edit window.
If I Point to the mfx folder (Fieldrecorder, Save and Index) also non af the multitracks are seen.
Multitracks are only seen if I import all audio separetely.
But i never see metadata in any import.
Sometimes i have a scene where metadata and correct track names are available. So generally it should work.
I did a test with nuendo. It the same here.
I suspect an error on Mediacomposer/operator side.
Why do they change all Multichannel WAV from set to mono mfx files? (1 Channel is seen during import. They are all MonoFiles)
Ale
Old 11-03-2020, 01:35 AM
Originally Posted by Ale View Post
Hi Frank
Ale
MC always uses split mono files, unless I think they are using some linked workflow which has it's own pitfalls. I don't think it's often used. Split mono is perfectly normal.
There's no easy way to actively remove meta-data on the MC. I'd rather suspect some semi-pro recorder that simply doesn't do meta-data or the files were processed before import into MC stripping out all meta-data.
Could have many reasons why it's gone. Do you have the original BWAVs? If nothing is in those I guess that's the cause. Messed up workflow and/or consumer gear used to record? Look at the original BWAVs,m if they are empty as well, it was messed up during the shoot. Or someone remove the meta-data somehow before import. Or they used a meta-data intransparent third party machine to sync the dailies but I donIt think there is one. You'll know more when you look at the BWAVs from set.
Old 11-03-2020, 02:08 AM
Ale Ale is offline
Thanks Frank
I will have a look into the originals.
In Mediacomposer the tracknames are imported
I do not understand where they get lost but I will investigate together with the production company
Ale
File Type: png Bildschirmfoto 2020-11-03 um 11.03.57.png (45.8 KB, 0 views)
Old 11-03-2020, 02:18 AM
Ale Ale is offline
But again Frank
When you say you just import AAF und you also get the multichannel files.
What do I make wrong cause I only see the track that is in the timeline.
Ale
Old 11-03-2020, 03:46 AM
have you got view/clip/channel-name active?
In terms of the timeline of course you only get what's in the AAF track-lay, for the other tracks you need to use the expand function. It's part of the field recorder workflow functionality.
Old 11-03-2020, 05:19 AM
Ale Ale is offline
Hi Frank
Thanks for yout time and input.
Yes, all activated. See picture what I see
Field recorder expansion gives me all hidden tracks but no metadata.
This time the part of this series comes from an Aaton Recorder.
The cutter told me that they dont get the metadata from the Recorder and they manually edit names on every take!!
They send me the original files. Lets see what happens then.
Ale
File Type: jpg Bildschirmfoto 2020-11-03 um 13.22.24.jpg (85.1 KB, 0 views)
File Type: jpg Bildschirmfoto 2020-11-03 um 13.47.36.jpg (86.4 KB, 0 views)
Old 11-03-2020, 06:23 AM
Hi Frank
Ale
Cantar is a special case. You don't see the meta-data because it's not in the files, they only punched it into the bin database. you need to expand to the original BWAVs. The Aaton requires an import via ALE into the AVID (as it only writes the track info into the iXML field, the recordists should have told them) but it's too late for that now. As long as the expand works that's fine. Just expand to the original BWAVs and you should be fine. That's what that workflow is for in the end.
Since you are German: There's a whole chapter on this workflow with Cantar in the "BVFT-Filmtonguide". Do you have that?
Old 11-03-2020, 02:14 PM
Ale Ale is offline
Hi Frank
Thanks for the information.
I found it on their Hompage.
I forwarded info to cutter and wait for the original files.
Ale
HTML code is On
Metadata from AAF from Premier PRO lost SindriKara Tips & Tricks 0 07-25-2019 08:47 AM
How to change metadata on audio files? Inglesworth macOS 1 02-24-2017 04:34 AM
Key Command for finding audio metadata please help ickeruss Pro Tools 9 0 04-13-2011 07:52 AM
reading Audio file metadata ? KingFish Pro Tools TDM Systems (Mac) 4 05-05-2009 02:08 PM
Reading audio file metadata???!!! GeneOuse Pro Tools TDM Systems (Win) 1 01-21-2008 10:07 PM
