Re: Pro Tools 12 - Video engine won't launch
Have you tried moving the video file to another drive or internal. And have you tried transcoding to ProRes or DNxHD ?? I am on my phone now so sorry if I cannot remember if u r Mac or PC
Yes, I tried moving the video file to an internal drive as well as trying a completely new video file. Same thing happens. Engine Launch pop-up box seems to finish loading, but nothing happens. I even let it sit for a few hours. Nada.
DNXHD or PRORES is recommended for video encoding format to be use with PT12 and H264 sometimes causes problems.
convert the vid then try launching pro tools and create create an empty session, then enable video engine in the SETUP --> PLAYBACK ENGINE menu. quite the current empty session and try opening up your session with the vid again again. |
That is strange, the video is provided by Avid for Certification of PT 12. If they knew that there was a problem using the H264 codec, then that would be an oversight on their part.
I would have to do some searching on conversion from H264 to DNXHD or PRORES. |
install the avid codec pack from the pro tools install and use the mpeg streamclip app to convert to DNXHD format.
#16
i found nothing wrong with the video as H.264 ... i tested in pro tools 12 ... so it is not a codec thing ...
i doubt Avid would let this video out if it did not work .. Avid website H.264 (Performance may vary) but this is not perfromance obviously ... something is missing !!! Austiin, please remind us Mac or PC ??
#17
- Max OS Sierra (10.12.5)
- Pro Tools (12.8.0) I even tried an old video I had worked on years ago and still nothing. |
#18
Here are some more specs to see if this will help out.
Model Name: iMac Model Identifier: iMac12,2 Processor Name: Intel Core i5 Processor Speed: 2.7 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 6 MB Memory: 16 GB I'm curious if my Mac is no longer supported since the upgrade to 12.8 Drew, Jeffro, Connor .. Just wanted to tag you three to get your feedback. |
#19
Also, on a suggestion from a friend (Hi Josh! Sorry, John!), I opened up Logic Pro v9 and opened the movie and it worked just fine. So, hopefully that should mean that it's not my video card.
But, that might mean that my Mac is not supported when it comes to the PT Video Engine. |
#20
Quit PT
Use "PT Prefs" http://petegates.com/pg-pt-prefs.html to trash Databases (check the last 7 boxes if you don't want to waste too much time checking which makes what) Restart PT
Making sounds and music. Love both. |
Avid Video Engine won't launch | carlone | Pro Tools 12 | 0 | 07-04-2015 12:57 PM |
PT 11.3 / OS 10.10.2 video engine won't launch | kkabel | Pro Tools 11 | 3 | 02-13-2015 03:42 PM |
Video Engine Won't Launch in Pro Tools 11 | haudio | Post - Surround - Video | 10 | 11-23-2014 07:57 AM |
Video Engine can't launch | soundista | Pro Tools 11 | 1 | 07-15-2014 04:52 PM |
Pro Tools 8 LE stalls at video engine launch | Tommy Barth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-13-2009 01:44 PM |
