Old 07-09-2014, 12:01 PM
arjohe arjohe is offline
Default PT 10.3.0 OK with PT 11 on Mavericks?
Im aware that co-install of PT 10.3.0 is not possible with Mavericks and PT 11. But what I don't know is that will PT 11 work fully ok in my Mavericks 10.9.4 as I now have PT 10.3.0 there as well, even I don't want use PT 10 anymore at all?
I just want to make sure that PT 11 works even my PT 10 is still there because I can't uninstall PT 10 anymore since I have mavericks and uninstall is not supported by Avid with mavericks...
(Yes, I should have uninstalled PT 10 it before Mavericks update but....)
Old 07-09-2014, 12:51 PM
Craig F Craig F is offline
Default Re: PT 10.3.0 OK with PT 11 on Mavericks?
you need 10.3.6 or higher for a co-install 10.3.5 and below will have problems do to a difference in files location in the System Folder
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 07-09-2014, 02:15 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
You can manually remove Pro Tools 10 using the instructions in this Knowledge Base article:
How to manually uninstall Pro Tools 10 and Pro Tools Express on Mac OS X Mavericks 10.9.x
Bruce Paine
System Details
Old 07-09-2014, 09:52 PM
Thanks a lot for link! This is the way to go especially if PT 11 would not work with PT 10 still in my system.
Old 07-12-2014, 04:25 AM
JFreak's Avatar
JFreak JFreak is offline
Actually, if I was you, i would have a separate partition for PT10 and leave it alone as soon as you have installed and tested everything. Have PT11 on another partition, which you will sooner rather than later upgrade to Yosemite...
Janne
Mac OS X 10.9 Mavericks ONLY! marianna FireWire and USB Audio Interfaces (Mac) 6 05-16-2014 11:21 AM
PT 11 / TDM / Mavericks DannyG Pro Tools 11 2 03-27-2014 08:15 AM
Anyone using 11.1 with Mavericks 10.9.1? boxedin Pro Tools 11 3 12-30-2013 12:19 PM
PT 11 and Mavericks James Drake macOS 12 12-03-2013 06:49 AM
