No playback sound after recording
This is very frustrating... I can record with monitor but it doesn't playbck....
The interface Im using is Duet 2, and I've been recording vocals fine with Garageband and there has been playback after recording. After installing Pro Tools 10 and activation and everything, I can record vocals and everything seems to be fine, I changed the playback engine in Setup to Duet and IO input and output seem to be right, and monitor is on, everything sounds fine while recording, and the initial beep sound to indicate the beginning of recording can be heard. But after the recording, I click play and there's no playback sound, which is very frustrating, as if the output is put to sleep, and no sound would come through any other audio resource either, for example if I open iTunes and there would be no sound. And then I have to quit Pro Tools and open it again and start all over again so there would be sound while recording, but still no playback sound again and the output is dead again. I've already uninstalled Pro Tools and re-installed it but the same problem still happens. It never happens if I'm using garageband. I don't have an external hard drive at the moment but the computer has 250G space partitioned..... should that be the problem? |
Re: No playback sound after recording
1. Are you attempting to record to an AUDIO track not an AUX?
2. have you selected the appropriate input to the audio track? 3. Is there a waveform created? 4. Have you tried playback without the track record enabled? |
Toggle input Modes with ALT+K
2 i think the input was fine because i could record with monitor on and the waveform showed normal 4 I have tried without the track record enabled but there was still no sound |
It sounds like you are getting a signal to the channel and recording it. Therefore, I would look at the channel output. Is it mapped correctly say, Analogue 1&2 and is this set to output through the Duet?
If you have input monitoring on you will not hear playback.
good point, and it did seem to be the problem, cuz whenever i clicked play there seemed to be volume but full blast and no sound. but i switched to auto monitoring on but still didn't work... is there a way to turn it completely off ? ....
yes that is exactly my output through Duet. and i can hear playback if i only play an audio backing track without recording, there's no sound only after recording..... so every time after recording, no any sound would playback....
Buzzing Sound During Recording and Playback | Tman311 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-22-2014 06:53 PM |
SOS No playback sound after recording | andisheep | macOS | 14 | 04-20-2013 09:24 PM |
After recording vocals, there is no sound during playback. Why? | sfwdslashx | Pro Tools SE and Essential (Win) | 8 | 10-25-2012 07:21 PM |
No sound when playback after recording | chillax69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-12-2006 12:32 PM |
No sound in recording or playback? | peetr3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-11-2005 11:38 AM |
