Old 02-21-2018, 12:08 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Eleven Rack Output to Amp 1 - Problems
**Disclaimer** I have not fully troubleshot my setup. So it could be user error but I doubt it.
I have my 11r that I use live (maybe 3 nights a week). I run it as a front side effects for my Traynor YCV40 - Tube Amp. This setup has been working great for about 4 years or so.
So I had problems recently and my sound was bad.....Distorted on the clean channel - Noticible breakup....when I should hear fender style cleans.
Found the power amp tubes bad, replaced...now it sounds good again....no real problems up to here.
Back in service and I hear the cleans dropping that breakup sound again....(I assume tubes) but once I removed my 11r from the setup...my good sound is back.
I put a boss chorus and boss delay pedals in the front of the amp and it sounds all good.
Seems to me the 11r might have an issue......Has anyone dealt with this before?
Daniel
Old 02-22-2018, 10:56 AM
PRSWILL PRSWILL is offline
Default Re: Eleven Rack Output to Amp 1 - Problems
Check the master settings in the edit window to make sure you're sending the effects only- not the cab or amp modelling as well. I had this issue and that fixed it.
Old 02-22-2018, 11:38 AM
YYR123's Avatar
Amazing I will - thanks
Daniel
NO OUTPUT SOUND -- Eleven Rack, PT 11, OS X 10.9.3 -- JRH1292 Eleven Rack 1 09-07-2014 12:00 PM
Eleven Rack and output to speakers sricabla macOS 0 05-09-2014 12:45 PM
Eleven Rack Output to Amp dress4riot Eleven Rack 1 03-26-2013 10:59 AM
Eleven Rack no output HELP US! Markownage Windows 3 08-04-2012 06:47 PM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
