Old 02-13-2018, 12:44 AM
doboba doboba is offline
Default Loss of mix/mastering when bouncing to MP3
Hi there, first time poster.
So I recently completed a track, which I mixed and mastered to avoid distortion, yet when I bounce the track to disk (whether online or offline, with highest quality mp3) distortion that wasn't there has been introduced to the mp3, panning is gone, and my levels are off.
Any suggestions?
BTW I'm working with Pro Tools 12.8.1, Dell Latitude with Windows 10 64-bit, and a Steinberg UR44 interface.
Old 02-13-2018, 02:25 AM
Sardi Sardi is online now
Default Re: Loss of mix/mastering when bouncing to MP3
What does it sound like if you bounce it as a lossless file? So wav/aiff. Same issue?
Old 02-13-2018, 06:15 AM
Nope, no problem with a WAV file.
Thanks for the help, still wish I knew why it wasn't coming out right as an MP3 though ...
Old 02-13-2018, 06:34 AM
There’s no reason why that should happen. None at all.
If you take that wav and convert it to mp3 in another app like iTunes, I’m assuming it sounds correct? If so, that’s a workaround for the time being until you can resolve the issue.
Old 02-13-2018, 07:34 AM
The Weed's Avatar
The Weed The Weed is offline
Since you're on Windows, try converting the Wave file with VLC.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-14-2018, 04:28 PM
David Every David Every is offline
Doesn’t it use QuickTime to do the conversion? Maybe there’s something going on with that?
Also have a look and check the channels you’re bouncing out from
Old 02-14-2018, 04:46 PM
What exactly are you bouncing? One of the tracks in the session or the main output? That would seem to be the first thing to suspect here.
Bouncing tracks quality loss. Kemo3ce Pro Tools M-Powered (Mac) 14 10-03-2010 02:41 PM
Volume loss after bouncing to disk MaryJane Post - Surround - Video 5 12-09-2008 09:18 PM
Volume Loss after Bouncing to Disk smoothjay62 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 37 11-01-2007 03:08 PM
volume loss after bouncing iamsaved 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-01-2007 09:22 PM
bouncing to disc and volume loss takeouttonys Tips & Tricks 17 11-18-2004 09:07 AM
