Old 01-14-2018, 11:30 AM
mboxpro mboxpro is offline
Default Maximum number of physical tracks
Hello, I have an old Protools 24 mix with 4 cards. As far as I know I could connect as many as 8 888/24, because every card can handle a maximum of 16 physical tracks.
Well, my question is about if it is possible to have the 64 physical channels, running at the same time, or if it is the theorical limit, and it depends of other parameters as the computer, the processing in every card, etc...
Thank you
Old 01-19-2018, 12:23 PM
Default Re: Maximum number of physical tracks
With a system that old, it will likely be best to simply add tracks in a blank session and see where it runs out. Just open a blank session, select New Track and type 64 in the box and see what happens. Either it will populate with all 64, or it will tell you what the limit is
Maximum Number of tracks already exists in current config? lorenaguey Pro Tools 12 0 05-12-2017 08:46 AM
maximum number of simultaneous I/O songman macOS 2 12-31-2011 11:35 PM
The maximum number of tracks already exists for the current Pro Tools configuration wreckthisplace Pro Tools M-Powered (Mac) 2 09-28-2011 10:53 PM
Maximum physical outputs from Pro Tools HD? CamM Pro Tools TDM Systems (Mac) 2 04-20-2011 12:58 PM
maximum number of deliveries? KingTor Aspera DigiDelivery 2 05-08-2008 04:56 PM
