Old 11-15-2017, 04:06 AM
Raoul23 Raoul23 is offline
Default Highest OSX to run pro tools 10 HD
At the moment i'm on Lion, what is the highest OSX i can upgrade to without issues and and is it just a simple upgrade or do i have to start from scratch with a clean install.
Thanks Guys
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 11-15-2017, 05:58 AM
Southsidemusic's Avatar
Default Re: Highest OSX to run pro tools 10 HD
10.8.5
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-15-2017, 07:08 AM
Thank you, is it just a simple upgrade or a fresh clean install
Raoul Crane
Old 11-15-2017, 07:30 AM
When we were running those OSX Versions back in the day we just ran the installer over the older one. I have never done it anyother way and we are nowo. sierra and High Sierra on all Mac computers here. No issues has popped up for the past 7 years.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 11-15-2017, 07:44 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks Guys
Ive got an 10.8.5 boot as well but for me personally it runs better on 10.7.5 Also the graphics driver on 10.8.5 for me isn't compatible with my monitors. so i don't really see any advantage going to 10.8.5
If you're going to go there then use CCC carbon copy cloner to clone your Lion drive to another drive and update from there and see how it works for you.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-15-2017, 07:48 AM
Thanks Chris. I’ve back up my drive with Time Machine is that not any good to use. Only reason I’m thinking of up grading. To use Rig manager with my kempers I need to be on a different OS
Raoul Crane
Old 11-21-2017, 12:35 PM
Samanthas Dream Samanthas Dream is offline
I had no issues on 10.9.5, uninstall is a pain, but maneagable..
Old 11-24-2017, 04:08 AM
What do you mean by this??
Raoul Crane
Old 11-24-2017, 09:36 AM
The normal uninstall doesn’t work, so you have to do it manually, which is not that big of a deal really. Do a search and you’ll find the instructions.
Old 11-29-2017, 10:38 AM
marcelkavka marcelkavka is offline
10.9.5 is fine.
10.8 is kind of stone-age
Highest quality wav to mp3 method? alexmoi Pro Tools 10 2 10-16-2012 06:03 PM
Highest settings RuffinMedia macOS 3 02-02-2012 08:21 AM
What is the highest update I am authorized to use with 6.8? komplex Pro Tools M-Powered (Mac) 2 12-03-2007 05:39 PM
Highest version of LE on MAc OS 9 ? audioboffin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-21-2004 01:46 AM
Highest version of MacOS... imix4you General Discussion 1 09-20-1999 10:01 AM
