Old 09-28-2013, 02:05 PM
Cal D Cal D is offline
Default Re: Rendering midi to audio
It is good advice and I like the template idea as well. Thanks to all who weighed in. I appreciate it.
Old 02-06-2016, 02:30 AM
firmflange's Avatar
firmflange firmflange is offline
If you want to do a destructive edit (converting the instrument clip to a audio clip) in a few seconds, solo the desired track and select the "commit" option.
Old 02-07-2016, 08:21 AM
GoGoJoe GoGoJoe is offline
If your using your midi controller to control virtual instruments then your should be using virtual instruments not midi tracks.
If your recording with an outboard synth and would like to record the sounds of the synth you would need to hook up the midi in and out plus you would need to hook up the line output from the keyboard to the input of your interface. Them you would clean up the midi notes in your daw, Replay amd record the audio of the midi. This how the pros do it when using outboard synths. Just note without a daw with a truly customizable patch program your going to be limited to General Midi patches .. other DAWs do a better job of this.
There's no automated way to make all midi tracks convert to audio (that i know of )because the decision needs to be made by you if something is going to be mono or stereo sound. You don't want a Stereo kick. You don't want a Stereo bass. But you may want your high hat stereo or piano etc.. something to think on.
PC Dell XPS 8700, i7 CPU @ 3.40GHz, 4 Core(s), 8 Logical Processor(s). 32 GB RAM, Windows 8.1
Recording Pro-Tools 12.4. Mbox Pro 3 (Driver 1.1.10) FireWire CPU Interface w/ Presonus FADERPORT.
Audio gain not rendering MarkWorsnop Pro Tools 10 3 03-10-2013 02:59 PM
Rendering Elastic Audio Swagstaff Pro Tools SE and Essential (Win) 0 10-17-2012 04:55 PM
Rendering Audio Question KenRyan Tips & Tricks 2 09-20-2011 07:25 AM
Elastic Audio not rendering ALL REGIONS Kourquie Pro Tools TDM Systems (Mac) 1 10-04-2010 10:26 AM
Elastic audio rendering solution bterry343 Tips & Tricks 0 02-19-2009 12:56 PM
