switching Plugs from TDM to RTAS for my whole session
Is there a way to switch all my plug-ins from TDM to RTAS for the whole session instead of having to do it one by one ? Thanks
Re: switching Plugs from TDM to RTAS for my whole session
not as far as I know.
greetings, matthias
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ |
It would be awesome if there is a way!
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2 redtuxedo.com milkmoneyconsulting.com mindexpansiontechnology.com |
Try'
Open one of the channels' plug ins say in slot A to start. Select all the channels you want this to apply to. Press Shift & Alt together, then click on the TDM tab under the bypass tab in the plugin and change it to RTAS. This should change all the plugins in slot A of all the channels you have selected.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Hhhmmm.
Evidently your understanding of written Engish may need some assistance. The 1st clue being the word "try" the second being the word "should". . if I had know "definitely" then the 2 clues would have read, "do" & will" I will "try" it tomorrow in the studio & get back to you. Easy now . .
Open any plugin, and hold Option (Alt on Win) while selecting "Convert to RTAS" THIS will convert all "Same Insert slot" plugins across the mixer to RTAS
Repeat for additional insert slots
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Nice!! Now, I have to ask.....WHY do you need to do this?
I'm not the OP, but I can think of a good reason to do this: Say you are taking a recording session, where real-time TDM plugins were important, and converting it into a mixing session where latency is a non-issue. Now you want to be able to use a lot more plugins. By converting your TDM plugins to RTAS you greatly increase the number of plug-ins you can instantiate. You can still use TDM hardware for TDM-only plug-ins. This sort of resource juggling is particularly important when working at higher sampling rates.
PT9.0.0, 3.0GHz Mac Pro, OS 10.6.3, 13GB RAM, HD6/Accel, Magma PE6R4, PRE |
i was trying to figure out this very keystroke the other day in an HD3 lab (for the very reason you stated) - would have saved me about 10 minutes.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
Switching to AAX from TDM/RTAS Questions. | Dizzi45Z | Pro Tools 10 | 12 | 10-22-2011 03:07 AM |
Stop PT Switching RTAS To TDM | andyj4308 | Pro Tools TDM Systems (Mac) | 18 | 07-18-2010 07:08 AM |
Waves plugs require frantic window switching | dopplah | Pro Tools TDM Systems (Win) | 0 | 03-22-2010 07:50 PM |
Thinking of switching from PC to Mac. Will my plugs switch as well? | TeleKing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-23-2009 08:45 AM |
Thinking on switching to PC - what is the status on XP, PT LE6, and plugs for dual P | phobia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-19-2003 05:13 PM |
