Pt 12 & FL 12 Sync via CooperLan
I was able to sync Pt 12 (Master) & FL Studio 12 (Slave) via CooperLan but when I hit play in PT the position marker does not move. How can I fix this?
Please help |
Re: Pt 12 & FL 12 Sync via CooperLan
What protocol are you using to make the sync? MMC? MTC? ReWire?
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
I am using MMC
Just seeing if you finally got this running and what solution you went with.
Shane
Hi Shane,
I was able to get Fl Studio & PT to work half way. If i press play on FL Studio, the clock runs on Pro tools but that is it. Nothing else seems to work. I can't find a solution |
Try this by forum user rmwtech:
http://duc.avid.com/showpost.php?p=2334213&postcount=2 You'll have to do the equivalent Windows actions, but hopefully it'll get you there. Shane
Hi Shane
Thanks I will give it a shot. :) |
Pro Tools 12 CooperLan Sync | Sid0 | Windows | 2 | 01-18-2016 05:34 PM |
Sync HD reverts back to loop sync after PT quit | [email protected] | macOS | 1 | 07-23-2015 02:37 PM |
Sync Audio - Editor Used Camera Track Only -Waveform Sync? | milosziv | Post - Surround - Video | 7 | 11-30-2011 05:26 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Sync Processor's Tremolo to Midi Time Sync via Interface | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-01-2000 12:08 AM |
