Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
  #91
Old 01-11-2014, 10:10 AM
flautista's Avatar
flautista flautista is offline
Default Re: Mbox 3 DSP FX Broken?
No wasn't
I paid 140 us dollar
But you must know i am in Chile
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
  #92
Old 01-11-2014, 10:32 AM
flautista's Avatar
Originally Posted by serio View Post
a couple questions...
Was you're Mbox under warranty?
Did you have to pay shipping?
Where are yo from?
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
  #93
Old 01-13-2014, 12:09 PM
Stane Stane is offline
Default problem with the Tuner on Mbox
I have Mbox 3 Pro interface and ProTools 10 software. I have problem with the Tuner on Mbox - it doesn't work and also on ProTools software the Click don't work. Can somebody give me some suggestion how to repair this problem.
Stane
  #94
Old 01-13-2014, 02:25 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: problem with the Tuner on Mbox
Mbox Pro - FX & Tuner not working:
http://duc.avid.com/showthread.php?t...Pro+DSP&page=4
#35
05-22-2013, 02:27 PM
connor@@vid
Avid Join Date: May 2013
The issue is in fact firmware-related as members in this thread have speculated. We’ve handled a small number of cases in which the firmware update fails in such a way as to disable the onboard effects and tuner, leaving all other functionality intact. The number of reported firmware update failures is extremely low among units sold but we are aware of and investigating the issue. At this time, the only way to resolve this failure is to send the unit in for repair. You do not need to purchase an Avid Support Code to contact Avid regarding a repair issue. In North America please call (650) 731-6100 and press option 3 for the repair line. In all other regions please contact your reseller for repair.
It appears there is no way to rectify this issue with a firmware update. Once it corrupts you can’t reload it, so it becomes a hardware level repair. You’ll need to send it in, with an RMA (Return Material Authorization) number:
http://www.avid.com/static/resources...-2012%20v6.pdf
  #95
Old 01-13-2014, 07:33 PM
serio serio is offline
Originally Posted by flautista View Post
Where are yo from?
Florida, U.S.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
  #96
Old 01-14-2014, 05:02 AM
flautista's Avatar
Did you contact AVID ?
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
  #97
Old 01-15-2014, 02:43 PM
No, I had hoped for a firmware or driver update that would fix the issues but that may not happen at all. Avid's mention of covering "under warranty" units also discouraged me from trying to get service as I'm pretty sure I'm out of warranty. Though, after hearing about your positive experience, I'll probably do the same as you soon.
  #98
Old 01-16-2014, 03:10 AM
flautista's Avatar
You really must insist, Is problem caused by AVID EVEN WITH OUT GARANTY
WAS CAUSED BY AN ACTION CREATED BY THEM
A BAD UPDATE
wish luck
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
  #99
Old 01-16-2014, 06:12 PM
jryser's Avatar
jryser jryser is offline
Serio - you and I have had some issues with our MBoxes for a bit. I was able to use a code to get rolling and have gotten my problem taken care of. I was reasonable and not demanding, and had a great experience. There were a very small batch of mboxes that apparently had some funky thing going on and Avid and I came to a resolution that we both felt good about. I hope you will have an equally good experience; just get with them!
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
  #100
Old 01-16-2014, 11:56 PM
Wcutta Wcutta is offline
So if you are out of warranty (which I know I am) how much does a fix/replacement cost?
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
3tuner" and internal "DSP" doesn't work on Mbox Pro (3G) luckydjacks Windows 0 12-31-2012 04:40 AM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
