Old 02-15-2004, 10:18 AM
proxy proxy is offline
Default Shortcut for split at cursor
Anyone know a way (keboard shortcut?) to split a selected region at the playback-head, one that works when you are in the mode were selection & playback-head are independent? I'm working on a video project with lots n' lots of edits that need corresponding frame-accurate audio edits and my mousing-hand is about to fall off.
I'm due to hit the manual again for a reload, but as I'm in the thick of it right now, does anyone know this one? I'm on TDM 5.3.1.
Thanks!
- Proxy
G4 dual 1ghz QS (1.5gig RAM) / OSX v10.3.9 / HD4 / AD8K / PT v6.9
Old 02-15-2004, 11:19 AM
Shawn Simpson Shawn Simpson is offline
Default Re: Shortcut for split at cursor
Whenever the playback cursor gets to where you want to cut, hit the down arrow and that will drop the edit insertion cursor at that point in time. Then just use the seperate region command, Cmd+E. Have fun.
Old 02-15-2004, 11:25 AM
In your preferences, set Auto name separated regions - then you can use Command+E to split a region, or in command focus mode - you can just hit the B key... you simply place the cursor at the position inside the region you want to split, or make a selection inside a region which you want to make into a new region.
You can find a link to a list of keyboard commands in your Help menu.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-15-2004, 01:53 PM
Hey,
Thank you both - that plus "0" on the main keyboard hooks me up! Thanks again.
- Proxy
Keyboard Shortcut to tab cursor to next grid line? stpete111 Pro Tools 10 13 03-19-2020 11:37 AM
Keyboard shortcut - split stereo track into 2 mono critza macOS 4 02-12-2013 02:04 PM
Locate playback cursor shortcut? bublabs Tips & Tricks 1 06-08-2007 05:26 AM
D-Control 32 split or no split? Don Geppert ICON & C|24 8 01-30-2007 10:15 AM
