Old 05-09-2001, 11:19 AM
TriAxis TriAxis is offline
Default My IRQ says I have 2 Digidesigns in 10 and 11.
When I boot up the initial screen I see 2 things. Its when my PC lists the IRQ's in 10 and 11 it says I have 2 Multimedia devices. Then in my Windows, I look under this one section and it says I have 2 Digidesign's both under #10 and #11.
Is this normal or not??? My PTLE works pretty good, except sometimes the PCI meter will Max out. I also noticed my Display adapter and something called ACPI all use the #11 IRQ.
If I change my Digi board to a different slot will that help things. What things should I do before I try and move the board.
TriAxis Wuz Here!
DIGI003 Rack+ Factory
Intel Q6600, ASUS DH Deluxe, 8 GB DDR2 800 Mhz RAM,
ProTools LE 10 on Windows 7 64 Bit
digidesigns AS plugins joeydego Pro Tools M-Powered (Mac) 4 11-11-2008 11:32 PM
Digidesigns Hardware issues,post them here... gdx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-06-2008 11:40 AM
digidesigns hardware is in use problem! jakeelee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-26-2004 12:01 AM
Digidesigns support for Windows Holadrio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-17-2004 12:15 AM
What are Digidesigns plans for Surround Plug-Ins? Ah D O General Discussion 1 04-15-1999 01:39 PM
