Old 02-27-2024, 09:08 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default is there a plugin that ...
opens frequency dependant, then closes with a timed filter? For example a tom hit opens it full range then a low pass filter sweeps down over say 2 seconds so the LF of the tom remains, but the hats / cymbals are filtered out as the decay amplitude diminishes to a full close.
Am I making sense? Of course theres a bunch that will open by internal or external sidechain (fabfilter, Sonnox ..) that can be freq dependant opening, but its a timed filtered decay that I've looked for but not found - other than perhaps adding a soundtoys filter freak - but thats really not doing well what I am asking here.
Ideas?
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 02-27-2024, 10:00 AM
tope d's Avatar
tope d tope d is offline
Default Re: is there a plugin that ...
Ideas?
Hi There, have you already tried playing with Channel Strip?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-27-2024, 01:00 PM
AINSLIE's Avatar
ITs a great plugin but does not have the gate closing with a frequency relationship - It does have the filter side chain to open the gate as per sonnox and fabfilters gates. But I dont see it or any plugin with a time x frequency related closing.
Its a plugin someone should create! Any mixer that mixes a lot of live records would love it.
Old 02-27-2024, 01:10 PM
AINSLIE's Avatar
another scenario - an open live tubular bell mic near other live percussion. The opening transients of the bell hits have a lot of HF from the bell, but the decay of the bell has a lot less. As the decay progresses the bell mic then has a higher % of HF coming from the nearby perc. I want to keep the LF of the bell in the decay but have an LPF come down to filter out the perc in the decay.
I can see a lot of uses for this kind of tool.
Old 02-27-2024, 01:22 PM
saqibhassan saqibhassan is offline
Waves C1 gate does that
https://www.waves.com/plugins/c1-compressor
Old 02-27-2024, 02:01 PM
BScout BScout is offline
Originally Posted by saqibhassan View Post
It doesn't.
He's looking for a comparative (dynamic) filter. The side chain would have to compare a band-limited signal from the channel it is on to a secondary signal (side-chain also band limited) to determine the reduction of an LPF on the full signal. C1 can't do that even as a compressor (it's not comparative)
Old 02-27-2024, 02:07 PM
Eric Lambert's Avatar
Nothing comes to mind, but I like the idea.
Old 02-27-2024, 02:16 PM
I don't think this would ever work well because the threshold would be constantly changing (it's not stable like how ducking works.) Better to write in the LPF trim with automation.
Or set the LPF trigger on the tubular bell based only on it's attack. If you set the threshold, release right (and everything is relatively at a tempo) you should get the result you want. (using a multiband compressor)
Old 02-27-2024, 02:35 PM
AINSLIE's Avatar
If a gate can attenuate noise somewhat reliably between toms, surely a timed LPF filter could be triggered by the same gate opening. Drawing / writing automated LPF is something I have previously done but its laborious over a two hour show .
To saqibhassan - the C1 comp/gate does in fact do it to a point - but it doesnt quite have the control in the decay I would like - or the gate opening sidechain that would make this more reliable. So it kinda works - but not well enough for me. Id be better manually editing and automating to get a usable result.
Old 02-27-2024, 02:39 PM
AINSLIE's Avatar
Maybe an answer is a multiband gate I could duplicate the track, split the eq HPF/LPF and gate each separately to kinda get there.
HTML code is On
Plugin Window is too small cutting off access to most of the plugin GOOOTOOO Pro Tools 2020 7 09-21-2020 07:38 PM
Schoeps DOUBLE MS PLUGIN (2018) SURROUND PLUGIN FOR AAX finally available! bartosz idzi AAX Plug-ins 1 12-16-2018 03:49 AM
Bug: When selecting a favorite plugin insert, the plugin above the one selected opens DJ Hellfire Pro Tools 12 35 08-22-2017 08:05 PM
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 klyg Artist Series 2 02-29-2012 10:50 PM
Vocal plugin needed to change voice, what is the best plugin Logicdance Digidesign Hardware & Software 0 03-13-2007 04:26 AM
