Old 02-16-2018, 11:13 AM
jmuyco jmuyco is offline
Default Could not complete the Import Audio command because Assertion ... Line 570.
Hi! I'm new here.
I have a Macbook Pro (mid 2010), version 10.13. 3, OS High Sierra.
I run Pro Tools 10 through a firewire port on my G-drive (1TB) using my iLok. Recently I had tried to import some audio files into a new session (44.1 k 16 bit) and a dialog box popped up saying it could not be completed. This is the exact wording it came to:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/ws.Ludwig/AlturePorts/NewFileLibs/Cfd/MacBuild/ ../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 570.
Any ideas what this could mean? I've tried dragging and dropping the audio files as well and Pro Tools won't recognize it as anything. I've never had this problem before. I have a few projects I need to work on and this is the only thing that's keeping me!
Jo
Old 02-23-2018, 03:30 AM
Michy Michy is offline
Default Re: Could not complete the Import Audio command because Assertion ... Line 570.
I had a similar issue with pro tools 12.5.2 I still could drag and drop files but not import with +maj+I (it said line 603 if I remember) I reinstall everything but didn't do good. Eventually I saw a chinese topic who said (thanks to google translate) to downgrade to Sierra. Everything is fine now. HighSierra has a new format (APFS) I guess it's not fully supported by old protools.
I hope I helped.
Cheers
Old 02-23-2018, 04:52 AM
Originally Posted by jmuyco View Post
Hi! I'm new here.
Jo
Your problem is trying to run PT10 on an OSX version it will never be supported to run on. The last OSX to successfully run PT10 without issues is OSX 10.9.5 with the only thing being the PT uninstaller won't work. What do you mean by 'I run PT10 through a Firewire port on my G Drive'? Is PT10 installed on that drive? Programs are supposed to be installed on the system drive.
I hope I helped.
Cheers
APFS format only affects SSD's and not spinners. PT has nothing to do with whatever type drive format it's installed on.
IN either case when importing and having issues like these (especially if coming from an external drive) is to drag the file(s) to be imported to the drive PT is recording to or to the system drive. This sometimes helps.
Jack
QAPLA!
Can't import audio (Assertion Error) with Pro Tools 11 on El Capitan/later QaliStacks Pro Tools 11 94 12-22-2020 01:35 PM
Could not complete the Import Audio command because Assertion in "/Volumes/Developmen awodzanowski Pro Tools 11 2 03-22-2016 12:40 PM
Cannot complete audio import command Engine Room Pro Tools 11 1 01-19-2016 06:01 PM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
