PT10 Midi notes trigger randomly and spontaneously with Digi 002 console
Hi, I am trying to get my system working again; I have upgraded from PT8LE to 10.3.10 quite recently and I have been through a lot of issues. The last one is that I am experiencing random midi notes triggered spontaneusly in instrument tracks. Sometimes they are not even notes but some sort of midi information changing the pitch of the midi notes. Notes are triggered spontaneously right after I finish playing plugins midi instruments.
The most interesting thing is that everything was fine just a month ago with same set up using PT8LE (i.e. the only actual change in my set up is the upgrade from PT8 to 10; nothing more so most likely it is a PT issue interacting with my set up). Just in case, I've disconnected all the midi controllers except one to test but the issue still persists even with all controllers are disconnected (I have an arturia keyboard, MS20i and maschine studio). And I have a midiman 4x4 midi interfase (quite old and I have never had problems with it). Hope this is a well-known issue with an easy fix.. I am getting tire with all the problems after the upgrade (I am not upgrading ever again; my next system is a mac with logic; this is a nightmare and I see PT8LE really similar to PT10; yes, folks, yes, maybe PT12HD is a bigger leap but for me the upgrade for a rip off...). Anyway...many thanks for your help, Cheers HERE IS A SANDRA REPORT: Computer Model: ASUS All Series ASUS MB Serial Number: System Ser********** Chassis: Desktop Mainboard: ASUS Z87-A Serial Number: 1305118******** BIOS: AMI (OEM) 1007 05/17/2013 Intel vPro: 9.00.02.1345 Total Memory: 15.69GB DIMM DDR3 < Processors > Processor: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (4C 8T 3.8GHz, 3.8GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot: FC LGA1155 < Chipset > Memory Controller: TI PCI Express to PCI Bridge 100MHz, 16GB DIMM DDR3 1.33GHz < Memory Module(s) > Memory Module: Corsair CMY8GX3M2A1866C9 4GB DIMM DDR3 PC3- 14200U DDR3-1778 (9-9-9-25 4-34-10-5) Memory Module: Corsair CMY8GX3M2A1866C9 4GB DIMM DDR3 PC3- 14200U DDR3-1778 (9-9-9-25 4-34-10-5) Memory Module: Corsair CMY8GX3M2A1866C9 4GB DIMM DDR3 PC3- 14200U DDR3-1778 (9-9-9-25 4-34-10-5) Memory Module: Corsair CMY8GX3M2A1866C9 4GB DIMM DDR3 PC3- 14200U DDR3-1778 (9-9-9-25 4-34-10-5) < Video System > Monitor/Panel: Dell Computer DELL S2309W (1920x1080, 23.1") Monitor/Panel: LG EW224 (1920x1080, 21.5") Video Adapter: Intel(R) HD Graphics 4600 (20 SM5.0 1.25GHz, 256MB, PCI) Video Adapter: Intel(R) HD Graphics 4600 (20 SM5.0 1.25GHz, 256MB, PCI) < Graphics Processor > OpenCL GP Processor: Intel(R) HD Graphics 4600 (20SP 20C 1.25GHz, 1.5GB) Compute Shader Processor: Intel(R) HD Graphics 4600 (20SP 1.25GHz, 256MB) < Storage Devices > Samsung SSD 840 PRO Series (12:119GB (C:) TOSHIBA DT01ACA100 (1TB, SATA6:932GB (E:) HL-DT-ST DVDRAM GH24NS95 (1TB,:931GB (H:) HL-DT-STDVDRAM GH24NS95 (7.5GB:7GB (D:) < Logical Storage Devices > System Reserved: 100MB (NTFS) Storage (E:): 932GB (NTFS) @ TOSHIBA DT01ACA100 (1TB, SATA600, 3.5", 7200rpm, 23MB Cache) Elements (H:): 931GB (NTFS) @ HL-DT-ST DVDRAM GH24NS95 (1TB, USB2/SATA150) Hard Disk (C:): 119GB (NTFS) @ Samsung SSD 840 PRO Series (128GB, SATA600, SSD) Komplete 9 (D:): 7GB (UDF) @ HL-DT-STDVDRAM GH24NS95 (7.5GB, SATA, DVD+-RW, CD-RW) < Peripherals > LPC Hub Controller 1: ASUS Lynx Point LPC Controller LPC Legacy Controller 1: T0 C8-03 Audio Device: ASUS Core (Haswell) HD Audio Controller Audio Device: ASUS Lynx Point HD Audio Controller Serial Port(s): 1 Disk Controller: ASUS Lynx Point 6-Port SATA AHCI Controller USB Controller 1: ASUS Lynx Point USB xHCI Host Controller USB Controller 2: ASUS Lynx Point USB Enhanced Host Controller #2 USB Controller 3: ASUS Lynx Point USB Enhanced Host Controller #1 FireWire/1394 Controller 1: Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1: Intel ICH SMBus < Printers and Faxes > Printer: Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer: Microsoft XPS Document Writer (600x600, Colour) Printer: HP Officejet 6700 (600x600, Colour) Printer: Fax - HP Officejet 6700 (200x200, Colour) Fax: Microsoft Shared Fax Driver (200x200) < Scanners and Cameras > Scanner: Hewlett-Packard HP Officejet 6700 (NET) (Scanner, USB) < Network Services > Network Adapter: Realtek PCIe GBE Family Controller (Ethernet, 1Gbps) < Operating System > Windows System: Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance: x64 < Windows Experience Index > Current System: 6.7 -------------------------------------------------------------------------------- ***** End of Report ***** Last edited by Fredy; 08-13-2016 at 10:46 AM. |
Re: PT10 Midi notes trigger randomly and spontaneously
If you go to Setup (menu) > MIDI > MIDI input devices... what do you see there?
Re: PT10 Midi notes trigger randomly and spontaneously with 002 Console
Many thanks! your question already gave me the answer. Indeed, there was nothing wrong with my midi controllers.
I haven't gone there before; so I went there, disable one by one and test...The problem is "FW 002 MIDI MidiControl". It makes sense because I had to update the driver for the digi 002 console to make it work with PT10. I have nothing conected to the MIDI ports in the console. I do have a midiman 4x4 for that and fortunately, no errors there. I can definitely live without using the midi ports in the 002 console so I think I am fine. Anyway, if you know how to make the MIDI ports back to work with 002 console, please let me know. Again, great help! Many thanks |
Re: PT10 Midi notes trigger randomly and spontaneously with Digi 002 console
Glad I could help.
If you re-connect the 002 and record some MIDI - what do you see in the MIDI Event List?
The 002 does not need any setup in Midi studio to allow midi to work. Its any external midi triggering devices that need setup(like a keyboard or an electronic drum kit). Let's say you want to use an old synth as a midi controller to play MiniGrand. Connect a midi cable from the synth(midi out) to the 002(midi in). Then go to Setup>Midi>Midi Studio and create a new instrument. Name it whatever you like(my Yamaha Motif es8 is named "Motif" without the quotes). The next options are brand and model, but those can remain blank as they don't matter. The next detail is the crucial one. The midi input port MUST be specified. In your case, it would likely be "002 Midi In[Emulated]" or similar(but the proper choice should be a selection so it should be an easy choice)
I sold my 002 a long time ago, but ran the Motif and a Roland TD10 kit for years with great success
12.3.1 midi bug - some notes (randomly) are not playing | muesli | Pro Tools 12 | 4 | 12-04-2015 08:24 AM |
Drumamgog and Trigger skipping MIDI notes | benromsdahl | Windows | 2 | 12-27-2011 02:46 PM |
Cursor randomly chopping MIDI notes. | MrChrisos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-07-2009 01:48 PM |
Midi randomly cuts out and sustains notes | MPStevo | MIDI | 0 | 08-15-2009 09:25 AM |
DIGI Midi notes to trigger REASON help !! | syMPh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-11-2002 11:38 PM |
