Old 05-25-2016, 06:23 PM
groovebrother groovebrother is offline
Default PTHD10 (TDM)+Reason 4+CPU Overload
Hi Everyone,
is it reason-able to use the following gear in rewire ? :
16 x dr rex
4 x thor
6 x mixers
2 x mc EQ
3 x red drum
1 nnxt synth
+ 38 audio tracks
PTHD10 24/96 session + pe6r4 + 1 core+5 accel cards.
MP mid 2010 + 32 gig ram + 10.6.8
... i get constant cpu overload with pro tools asking me to increase the cpu usage limit when playin the 4 thors together.
I tried with the thors only but i get the same error message.
thx for any suggestions before i start transforming rewire into clips in pt
... not sure it would work if i try that same gear with 10.8.5
Old 05-26-2016, 05:04 AM
Default Re: PTHD10 (TDM)+Reason 4+CPU Overload
What cpu(s) do you have in that Mac? Depending on that I'm not surprised you're having issues. I've found Thor on even my system to be a bit demanding cpu wise.
Jack
QAPLA!
Old 05-26-2016, 08:48 AM
its a 2,8 ghz quad core xeon
i gess its no way to use 4 thors with that mac, but that's okay i'll find another way
thx anyways
Old 05-26-2016, 01:51 PM
DetroitT's Avatar
DetroitT DetroitT is offline
try 24 bit 44.1Khz (Just to see)
Both are running 32bit however buffers can change (in Reason and Pro Tools)
Old 05-26-2016, 03:51 PM
i know its working cuz i haved tried several combis long ago but as i could manage around 5 without unwanted noise, i thought thors would fit - even at 96k.
I gess i got used to that confort to have all in one session runing "live" till i tried these heavy pads in reason.
thank you all for ur time
PTHD10 Registration Barry Johns Pro Tools 10 2 08-10-2015 10:32 AM
RAM Cache in PTHD10 vs. PTHD11/12 reichman Pro Tools 12 2 05-05-2015 10:44 AM
cpu overload for no reason barefootrocks Pro Tools 10 5 07-29-2012 11:11 PM
PTHD10 for $599 now. Drew Mazurek Pro Tools TDM Systems (Mac) 41 11-02-2011 09:12 AM
CPU overload error with Rewire/Reason...wtf??? furdervish Pro Tools TDM Systems (Mac) 3 08-25-2008 12:00 AM
