Old 04-29-2016, 05:32 PM
cybership cybership is offline
Default Re: iMac 5K and PT12 ?
Originally Posted by albee1952 View Post
Avoid the Fusion drive
I know the Fusion drive was a problem early on but I wasn't sure if those issues had been sorted out with 10.11. Probably best to avoid them if possible though. Problem is they are standard issue on all iMacs unless you custom order.
Old 04-29-2016, 11:56 PM
bradch00 bradch00 is offline
Originally Posted by cybership View Post
Sorry to hear your having trouble. I see your using an external SSD. Do you use a Fusion drive for the OS and PT? Are all of your plugins updated to the latest version? Even when not in use, some plugins may cause problems if not up to date. If you haven't already please go over the troubleshooting list below. Let us know what you find.
http://avid.force.com/pkb/articles/t...Optimize-10-11
My 5k is a custom order 1TB flash drive internal drive that I have had no troubles with. That being said, I do run about 70% of the time from a thunderbolt 2 connected external SSD system drive, again with no issues. ( I use external drives for testing and QA). Audio sessions are stored on another SSD with samples served from a USB3 attached SSD.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 04-30-2016, 04:57 AM
stormking69 stormking69 is offline
Thanks for the info. Can you tell me more about your iMac? Which Hard Drive, i7/i5 and RAM? Also is it Haswell or Skylake?
Sorry for the delay. It's the late 2015 model, Skylake processor. i5, 16 gig RAM, internal HD is good old fashion spinner(1TB), record to external Glyph drive(500GB). Using the TB to FW connectors.
Old 04-30-2016, 06:43 AM
Thanks for the info. Do you notice any fan noise from your 5k when running larger sessions? I need to be able to record acoustic instruments in the control room. I've read some complaints about fan noise while others say it's rarely an issue. Which processor do you have Haswell or Skylake?
Old 04-30-2016, 07:24 AM
Although purchased in early 2015 it is a late 2014 release, therefore an i7 Haswell. The 2011 i7 it was brought into replace, did produce more fan noise under heavy load. The 2014 model (at least this one) is quiet.
BTW it was purchased with minimum RAM and I installed Crucial RAM for considerably less than Apple factory.
  #16
Old 05-05-2016, 02:51 AM
Leon550 Leon550 is offline
Thanks for helping, and sorry for the delay.
I was booting from an usb 3 SSD. For testing I moved the session over to the built-in SSD, brand new user, with the exact same response. As far as I know, all my plugins are up to date.
I did a comparison video
showing how the iMac and a Mac mini compares, using the same boot drive, and the same work drive. I would really appreciate your ideas as to why the new imac is so slow.
I feel that in this comparison, I have eliminated all variables except the computer hardware. Correct me if I'm wrong on that please! Also, the audio interface is different. (Mac mini has RME UFX usb, iMac has Apogee Symphony i/o usb).
Originally Posted by Leon550 View Post
It's bad. If you want to read my rant, please continue:)
Update: It might have more to do with cpu usage, as freezing all the tracks makes it almost lag free.
late 2015 5k
10.11.3
3.2 i5
32 GB Ram
SSD via USB3
AMD Radeon r9 m380 2048
Pro tools 12.5
It's horrendous. Quite a heavy session about 75%cpu
It lags like crazy. Scrolling is the worst, a second or two lag there. Resizing the window is also seriously laggy. Meters in edit window lag.
When opening a plugin like Slate VMR or Sound toys effect rack(already inserted, just opening it) First nothing happens, then the plugin window is black, then the rest loads, and finally the list to the left appears. Takes a second or two.
I'm actually wondering if the computer is all right. It's so much slower than my 2012 i7 mac mini with 1440p monitor.
It does not lag in other programs, like final cut pro x, so I'm guessing somethings up with my setup or Pro tools it self.
  #17
Old 05-05-2016, 09:52 AM
nstu nstu is offline
That looks very bad. I am waiting for the Mac Pro update but the iMac 5k would be my second option. Are there others with the same problem? If it only happens with protools than it must be a PT bug with the latest OS.
  #18
Old 05-05-2016, 10:40 PM
RythmSurfer RythmSurfer is offline
Hey guys, I just ordered an iMac 5k 27 inch with 3.3 GHz i5 processor and 2 TB fusion drive. Subsequently learned about these issues and contacted avid. Here is their reply (posted to another thread on this forum as well...)
1. ARE THERE ANY KNOWN ISSUES WITH PRO TOOLS ON MACS WITH FUSION DRIVE ?
Ans: Case to case basis. May or may not have issues. But on the tech's side they've encountered issues with Fusion Drives and SSD's. But officially, supports Fusion Drives starting on Mac OSX 10.9 Mavericks
2. WHICH VERSION OF PT IS COMPATIBLE WITH EL CAPITAN?
Ans: Pro Tools is compatible with OSX 10.11 since Pro Tools 12.3
regards,
Avid Audio
This sounds crazy to me!!! What do you guys think I should do? Is HDD a bett option?
  #19
Old 05-05-2016, 10:51 PM
Jacksonland Jacksonland is offline
I watched the video. I'm not seeing any of this lagging on my new iMac, but I have the i7 4 GHz. Curious why your Mac mini is an i7, and the new iMac is an i5.
Interestingly, my 5K Skylake with 4 GB GPU did have a lot of fan speed noise when I first turned it on and ran PT or even less demanding programs, but it hasn't been noisier than my older iMac since then.
MPEG, CAS, ATAS, NARAS
Izotope Artist
27" iMac Retina 5K, 4 GHz i7, 40 GB RAM, 4 GB GPU
PreSonus Faderport 16 and PreSonus Faderport 8
4 monitors - Neyrinck V-Control Pro
Focusrite Clarett 8PreX and Octopre Dynamic 96K 32bit
Vintage Neve 1073 and Sunset Sound Tutti Mic Pres
  #20
Old 05-06-2016, 01:04 AM
VRW VRW is offline
regards,
Avid Audio
I can just repeat it-if possible get the 4k 21.5" i7 Quad Core iMac with 16GB Ram and the 512GB Flash drive! This will be a great machine for Pro Tools 12.
Definitely better than the 5k 27" i5 iMac even if you can get an SSD instead of the Fusion drive.
The 5k 27" models have got graphic problems with OSX El Capitan and Pro Tools 12.5 at the moment (which may be solved by future updates) which the 4k
21.5" models seem not to have and the i7 Quad Core processor is a much better choice for Pro Tools than the i5 Quad Core.
Anyway if you cannot get the 4k 21.5" iMac, you may get the 512GB or the 1TB Flash drive for your 5K 27" or if this will not be possible as well just split up
the Fusion drive like described in one of my posts in the other thread and use the small 128GB Flash drive wisely (keep it clean and lean) and use the HDD
for other applications like Pro Tools audio or backups.
As mentioned in my prior postings with the 512GB or the 1TB Flash drive you even may skip the external Pro Tools drive as these are fast and large enough.
With any other set up you will have to use your external drive for your Pro Tools sessions and audio files further on.
The best of success to you.
Anybody using PT12 on 2011-2012 IMAC? ianmoore68 Pro Tools 12 8 03-28-2016 06:39 AM
Pt12.4 - iMac or Mac mini? Loganguy macOS 6 01-11-2016 05:55 AM
PT12.4HD on LATE 2014 IMAC vr Mac MINI davemartone Pro Tools 12 2 01-02-2016 02:48 PM
PT12 4K monitor vs new imac 27 vs nMP propower Pro Tools 12 9 10-16-2015 06:10 PM
PT12 and PT12 HD surround? theom Pro Tools 12 17 10-12-2015 09:27 AM
