Audiosuite causes pro tools to freeze
When I attempt to render or audition audio with an audio suite plugin pro tools locks up. I then have to force quit and loose what I haven't saved. Any ideas. It happens with waves and avid plugins.
Re: Audio suite causes protocols to freeze
It would sure help to know...
What version of Pro Tools? What are your system specs? Has this always been the case or did it recently begin? Have you made recent changes to your system? Are your plug-ins ALL current? Not just the ones in use, but all that are installed.
Hi... I am having a similar problem. I recently upgraded to Pro Tools 11 and installed it as a co-install with Pro Tools 10. I uninstalled Pro Tools 10 (clean) before installing 10.3.9, then 11.1.3.
PT 11 audio suite plugins / Elastic Audio have not worked since initial install (they work fine in PT10). If I enable an elastic audio plugin, the task hangs on rendering the audio and I have to cancel it. If I use a 3rd party plugin (ReVoice Pro), capturing the audio causes the system to hang and I have to force quit (ReVoice Pro works fine in PT10). I've tried uninstalling both and reinstalling again... didn't help. I've searched the forum and googled the issue and came across others reporting similar issue, but I haven't seen any responses to help me troubleshoot this. Any ideas? Thanks in advance. |
We're not mind readers here and can't answer without more info. |
Sorry about that. I just joined yesterday and I input the details in my profile. Guess I need to set them up in my signature for them to show in the post. oops.
System Details iMac 27inch mid-2011 Mac OSX 10.8.5 Apogee Quartet Pro tools Native co-install: 11.1.3.325 10.3.8.378 (rolled back from 10.3.9) |
How did you roll back? Safe Uninstall? Clean Uninstall?
Clean install.
MacLa System Details iMac 27inch mid-2011 Mac OSX 10.8.5 Apogee Quartet Pro tools Native co-install: 11.1.3.325 10.3.8.378 |
p.s. The issue with PT11 was happening before I rolled back.
Thanks for the troubleshooting test list.
I performed all the tests you mentioned: 1. Enable Elastic Audio on a track before placing any audio files on it -- Same result: Enabling Elastic Audio on an audio track, then placing an audio file on it or recording new audio on it hangs on the Analyzing Audio task (the progress bar doesn't advance past the initial green sliver). I have to cancel the task. The result is the same whether stereo or mono track. Interesting... the Timeline Data Online Status indicator remains red even after I cancel the tasks and disable the Elastic Audio plugin on all tracks. Audio is rendered and audible on all tracks, but the indicator remains red. If I save the session, close it, then re-open. The Timeline Data Online Status indicator is green. 2. Set your session to use AIFF files and use File-->Import to load the audio files. Click the convert button (converts to AIFF on import). -- I set my session to use AIFF and used File → Import to bring in a WAV audio file, clicking on the “convert” button to convert to AIFF, then clicked “done”. The Import window closed and the Processing Audio task dialog popped up, but it hung – I finally had to cancel it. No audio was processed. 3. Set your session to use WAV files and use File-->Import to load the audio files. Click the convert button (converts to WAV on import). -- Same result when the session is set to Wav: I used File → Import to bring in a Wav audio file, clicking on the “convert” button to convert to WAV, then clicked “done”. The Import window closed and the Processing Audio task dialog popped up, but it hung – I finally had to cancel it. No audio was processed. 4. Try each Elastic Audio plug-in. Do you get the same result with each one? -- Yes, I get the same result with each Elastic Audio plugin. When I try to use an AudioSuite plugin (Reverse, for example), clicking “Render” will pop-up the Rendering status window and the session will hang (spinning beach ball). I can't cancel, I have to Force Quit. 5. Set your session to use multi-mono (not stereo interleaved) files. -- Same result whether the session is set to interleaved or multi-mono.
Missing plugins in AudioSuite / system freeze | noiseboyuk | Pro Tools 10 | 18 | 05-04-2014 01:21 PM |
Pro Tools 10 HD (Cursor Freeze/Playback Freeze) | vinlance | Pro Tools 10 | 1 | 07-13-2013 11:40 AM |
No track freeze? Nor process with multiple Audiosuite plugs at once in PT9?? | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-10-2010 07:54 AM |
Track Freeze and/or processing with multiple Audiosuite at once coming soon? | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-19-2010 08:24 PM |
HELP!! -audiosuite preview causes computer freeze | NAGEL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-21-2003 01:13 PM |
