  #201
Old 03-15-2014, 09:19 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Proper Recording Levels
One another thing to consider is the power supply of the analog gear. Even if digital is "perfect", analog is not. If you drive your analog stage to the extreme, it will sound nasty even though the digital side of the story thinks everything is alrighty.
Your final mix will likely have very much less than 24 dB dynamics so why bother taking risks? Just record lower levels, mix better, leave the hot levels to mastering.
I dare you. Next time you're tracking, prepare to record same song twice. One with hot levels and another with peaks at -20dBFS. Then mix both songs to your liking. Ask your best friend to pick which one (s)he prefers. I bet most of the time, the lower-level-tracked version is liked more.
Janne
  #202
Old 03-15-2014, 09:59 AM
mikeyman's Avatar
mikeyman mikeyman is offline
http://therecordingrevolution.com/20...m-in-your-mix/
here's a good one
  #203
Old 03-15-2014, 11:05 AM
JFreak's Avatar
Originally Posted by mikeyman View Post
Great article, worth reading if you don't already know this stuff...
Janne
  #204
Old 03-15-2014, 11:34 AM
bryced87 bryced87 is offline
Thanks that helps some with that article. I'm still wondering do I move the faders at all? Like what if I do want something louder can I turn pre fader off and just move the volume slider around a bit if I want more reverb etc?
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #205
Old 03-15-2014, 12:11 PM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Originally Posted by bryced87 View Post
Why would Paul Draper in the "In The Box Series" add an effect or compression to boost the level then trim it back down to -10? Isn't that just getting rid of what he did with the effect? He also never moves the faders around either which is crucial to mixing. He never once explains using volume automation or anything.
I believe he does do volume automations, but I think it's more of a gain staging series more than anything, yes? Per channel, per mix and finally mastering.
I think the first in his chain is the Klanghelm VU - but even if using an effect, it's possible that the resulting signal is to end up at -10 for mixing. Gain staging doesn't null effect results.
I bought the Klanghelm VU as a result of this video series and incorporated his methods with mine. I always like to pull all faders to around -12 and start my mix from there. Multiple layers of compression via channel (if necessary), group busses, parallel mix compression (ala Schoeps) ... My resulting final mix is about -18 - plenty of headroom.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
  #206
Old 03-19-2014, 08:16 PM
WillN WillN is offline
As a relatively recent sound grad and newbie on duc avid I would say thanks. Not only am I learning some *quality* advice from experienced audiophiles but that this specific thread has saved my skin this week.
  #207
Old 03-19-2014, 08:22 PM
mikeyman's Avatar
Originally Posted by JFreak View Post
Better yet, think of yellow as the new red. Record using pre-fader metering. Stay in the green. There's nothing to be gained in yellow/orange area, unless your AD converter has greater than 129dB dynamic range (24bit fixed has 144dB dynamics). Usually even the greatest ones are in the 120dB area so if you're above green you're just amplifying noise.
So... check your AD converter specs. If it says it has 120dB dynamics range, then anything hotter than -24dBFS is only amplifying noise. If you want to be sure to get all that 120dB dynamics in use, give yourself 6dB (equivalent to one bit) margin for error, and think of -18dBFS as maximum quality. Have you ever heard of gear being calibrated to -18dBFS = 0VU perhaps? This is why.
''Better yet, think of yellow as the new red'' That's It!!
  #208
Old 03-19-2014, 08:32 PM
mikeyman's Avatar
https://www.youtube.com/watch?v=O0VVWHjV130
  #209
Old 03-20-2014, 12:24 AM
JFreak's Avatar
Good to hear we're helpful :) welcome to the forum...
Janne
Question on proper levels LongRoad Tips & Tricks 11 06-14-2009 03:56 AM
rca recording levels/proper interface channel rygar22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-07-2005 12:21 AM
Recording Levels jawjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-20-2004 01:32 AM
Proper recording/monitoring of vocals MarkH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 08-16-2004 11:15 PM
*Recording Levels* mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-03-2002 09:10 AM
