  #101
Old 12-21-2013, 08:52 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Proper Recording Levels
Originally Posted by bcwiz View Post
The Digi 003 converters are fixed at -14dbfs.
Oh - I will have to find out about my Focusrite unit thanks
Daniel
  #102
Old 12-21-2013, 09:00 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Good question. Love those videos. I'm still trying to figure out where unity is on my 003. I searched everywhere for some information on this. There must be a way to find out?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
[email protected]
Live and Let Live
  #103
Old 12-21-2013, 09:02 AM
YYR123's Avatar
Unity - your fader and unity ur master fader in the software / proper gain staging from what I understood
Daniel
  #104
Old 12-21-2013, 09:05 AM
Default Proper Recording Levels
Ok then. What does that mean? Volume up all the way will deliver -14 to the outputs or anything coming out at any volume would be at -14? Bear with me please. I was never really good at math. Just trying to understand the VU, Dbfs stuff. 😝
[email protected]
Live and Let Live
  #105
Old 12-21-2013, 09:08 AM
No Y. On the 003 someone said there is unity. Say around 3/4 or so. How do I measure that? In the box all my faders are at unity.
[email protected]
Live and Let Live
  #106
Old 12-21-2013, 09:45 AM
bcwiz's Avatar
bcwiz bcwiz is offline
At 0VU you are 14db below 0DBFS (14db of headroom).
  #107
Old 12-21-2013, 10:02 AM
bcwiz's Avatar
An external meter, a voltmeter that can measure true RMS, a Dorrough or...
You could loop back and record the monitor output back into PT and see where the monitor control is at unity.
A 1k ref sine wave at OVU(-14 on digi003) should measure 1.23v rms at the output. That is +4dbm which is the common studio reference (analogue desk). Some interfaces cannot put out that level, Mbox 1&2 for example. You would be hard pressed to drive a console to proper level with the old Mbox.
The monitor out should be the same when you cal, in other words the same level as the main output. You could drive the speakers from the main out and the level is the same.
  #108
Old 12-21-2013, 10:11 AM
That's what I was thinking BC. Just plug my monitors into the 1+2 outputs instead of the monitor out.
[email protected]
Live and Let Live
  #109
Old 12-21-2013, 10:15 AM
I'll try that loop trick.
[email protected]
Live and Let Live
  #110
Old 12-21-2013, 10:54 AM
shtik shtik is offline
These two are the best threads I've ever read here on the subject, and they changed the way I look (or don't look) at recording or mixing levels ever since:
http://duc.avid.com/showthread.php?t=230766
http://duc.avid.com/showthread.php?t=252104
Question on proper levels LongRoad Tips & Tricks 11 06-14-2009 03:56 AM
rca recording levels/proper interface channel rygar22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-07-2005 12:21 AM
Recording Levels jawjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-20-2004 01:32 AM
Proper recording/monitoring of vocals MarkH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 08-16-2004 11:15 PM
*Recording Levels* mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-03-2002 09:10 AM
