Old 12-05-2011, 12:06 PM
helsabot helsabot is offline
Default Video regions stall at end when edited together
I'm editing a video montage project that involves cutting together multiple videos that were shot and saved separately. My process so far has been to import a clip into a new track, cut it to the desired length, and then drag it into place (shuffle mode) directly after another clip with no gaps in between. But when I play it back, there's a stall at the end of every clip before the next one starts - the last frame stays momentarily instead of going directly into the first frame of the next clip. I haven't had this problem when cutting together different clips from the same video.
Any suggestions?
Video Satellite LE and multiple video tracks or regions Erik Olsson Post - Surround - Video 1 01-12-2010 09:37 AM
Pop between edited regions John Peeples 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2008 09:10 AM
recalculate waveform overviews - on edited regions - how? tonmeistermat Pro Tools TDM Systems (Mac) 2 12-12-2007 10:36 AM
PT 7 ... stall before going into record? popps Pro Tools TDM Systems (Mac) 6 03-25-2006 11:34 AM
Locked regions can be edited! [6.1] jimlongo Pro Tools TDM Systems (Mac) 1 08-20-2003 07:04 PM
