Old 05-26-2011, 04:09 PM
smc917 smc917 is offline
Default DNX36 HD 23.976 QT Files will they play in PT9HD?
I am about to get some:
DNX36 HD 23.976 QuickTime Files will they import and play in PT9HD?
Dean
Old 05-26-2011, 05:46 PM
Craig F Craig F is offline
Default Re: DNX36 HD 23.976 QT Files will they play in PT9HD?
you have the Avid QT codecs installed?
you should be good
Thank you,
Craig
Old 05-26-2011, 09:37 PM
I am not at my machine at the moment.
Are the Avid Codecs a separate install?
Will the Avid Codecs be on the PT9HD install disk?
Or will I have to get them from another source?
Old 05-27-2011, 07:58 AM
drenkrom drenkrom is offline
I'm not sure if the codecs are included somewhere in the PT9 material, but they can be found here: http://avid.custkb.com/avid/app/self...p?DocId=372311
You have the Meridian's, DNxHD, MPEG50 and 1:1x codecs in there.
IHTH
Old 05-27-2011, 09:17 AM
Bydy Bydy is offline
The codec is not included with any PT install, you have to run the Avid installer linked above. You don't have to reboot the computer but you do have to quit and restart Pro Tools. The codec works fine with PT, though.
Structure LE won't play rx2 files teejmusic Virtual Instruments 7 10-14-2009 05:44 PM
? OG Mojo and DNX36 QuickTime Craig F Post - Surround - Video 0 06-02-2009 12:45 PM
Why can't I play .WAV files?? jlearman Tips & Tricks 2 11-20-2006 04:56 AM
Can't Play MP3 Files 100grit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-05-2005 11:18 AM
WAV files won't play New to it all Pro Tools TDM Systems (Win) 3 01-20-2003 01:51 PM
