Old 01-24-2011, 09:40 PM
critictalk critictalk is offline
Default Frequency suitable for TV
Well, just a question comes to my mind:
When we doing mixing for TV, what kind of frequency should we boost/roll off?
Because speakers from a tv, I believe, can't capable to distribute every frequency, so what kind of frequency should we boost/roll off to make a better TV mix?
Old 01-25-2011, 02:03 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Re: Frequency suitable for TV
A great mix translates across all formats IMO.
That said, if your track is extremely bass heavy its not going to have the same impact on a small speaker.
Old 01-25-2011, 09:28 AM
yes, that is the problem.
Some said that the mid-low and the high should be boosted up.
Old 01-25-2011, 01:31 PM
drenkrom drenkrom is offline
If you want to know how your mix sounds on a TV, set up a TV in the control room and find out. It's cheap and easy. You should never do any mixing specific to a format you can't listen back to, that's just guesswork and you'll damage the product more often than you'll save it. I was raised on the unflinching rule that any mix that will go into the wild should be listened to on "sheet"-boxes. (the DUC won't let me write "[bleep][bleep][bleep][bleep]boxes", which is an accepted industry technical term, no? )
A good mix will translate everywhere, but you have to check that yourself. There is no set recipe.
HTML code is On
Would this computer be suitable for Pro Tools 8? elephantapede Pro Tools M-Powered (Win) 0 08-01-2009 04:42 PM
Is this Macbook Pro suitable to run Pro Tools LE 8? Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-15-2009 06:45 PM
fw 'not suitable for playback' drthfdr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-04-2004 11:30 AM
Suitable Set-up Jason M Digidesign Hardware & Software 2 11-08-2001 08:35 AM
Suitable for use?? Dave-in-D.C. Pro Tools TDM Systems (Win) 0 07-03-2001 09:30 AM
