Old 12-04-2010, 01:38 AM
SDDP SDDP is offline
Default Can I use up to a 2 TB internal Hard drive?
I already have a few 500 and 750 gig internal drives, but I have one more internal hd bay left and need more space. There up to 1 TB, 2 TB, and yes even a 2.5 TB internal drives. Does anyone know if going past 1TB internal would work well for large 5.1 sessions?
I think I read somewhere that if you go larger than a 1TB, being that there are more plates it actually lowers the over all seek/read times and can be counterproductive?
I know the new 2TB have a 64 buffer/cache (hoping that might make up or help?)
Any input would be great as I'll need one soon.
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
Old 12-04-2010, 07:17 AM
Tweakhead Tweakhead is offline
Default Re: Can I use up to a 2 TB internal Hard drive?
just to confuse you further...
http://eshop.macsales.com/item/Hitachi/0F12450/
Old 12-04-2010, 01:23 PM
JFreak's Avatar
JFreak JFreak is offline
They're not adding plates or rw-heads, they're making the same plates denser (meaning the same plate holds more data). That also makes it faster, but none of that matters -- as long as WAV file can only be 4GB max.
Sure, you can have more files if you have more terabytes, but in case you wanted to record a longer continuous session, you're still out of luck. Don't know what you want to achieve by installing a larger storage, but just something to think about.
I'm currently happy with a stock 640GB system drive, a 10krpm 74GB work drive, and then I have backup storage that is always sufficient for my needs for the coming six months.
Janne
Old 12-04-2010, 04:34 PM
Thanks.. I don't use it at all for long continous sessions, recording is either VO, Foley, and adr and those are small files. So that's not a concern. It's the OMF are huge and with all the audio in a 5.1 can get huge. And rather have more room than I need with out ever worrying about space and 2TB would suffice. So basically the new internal Western Digital sata's at 2TB with 64 mb buffers would run just as smoothly as a 750gb?
-OSX 12.7.2
-HD Omni
-BM Intensity Pro
-HALO UP/DOWN MIX
-ANYMIX
Old 12-05-2010, 01:21 AM
Mystere1 Mystere1 is offline
I just reworked my Nethalem and replaced all the internal drives with the new 2TB digital caviar blacks. I also put an OWC SSD in the lower optical bay for the OS and everything is working great, better than ever actually.
Old 12-14-2010, 02:36 AM
Is that the one with the 6Gb/s and 64 mb cache?
I checked with apple tech support and they mentioned the 2008 Mac Pro 8 core won't work with the 6Gb/s, only the 3 Gb/s.
I was also under the impression that above 1TB it wouldn't work smoothly on the 2008 models.
Correct me if I am wrong though. I'd rather go for more, since I try to stay below %70 full.
Thanks for any info.
Old 12-14-2010, 05:27 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
I have a 2008 Harpertown Mac Pro. My internals drives are all 2TB, with the record drive being a 2TB Caviar Black. I run at like 60-70% full with no probs. I have a 2TB nightly backup mirror as well. I've had no disk related issues running the drives for over a year in this configuration. And I beat them mercilessly 7 days a week. I'm running large rock sessions, lots of VIs, 50-90 tracks. Its much better than my old system of daisy chaining drives together. YMMV.
brian
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 12-14-2010, 11:18 AM
Good to know. Thanks
Is it the 3 Gb/s or the 6 Gb/s?
And does maxing out with 4 hard drives cause the mac to get louder?
Old 12-14-2010, 05:40 PM
hmmm no idea if its 3g or 6g. I upgraded all to SATA 2, which I think is 3. and the transfer time between drives really picked up (copying files and such).
I've not had any drive hiccups. I'm not doing VE pro or big orchestral bits. But I do a large amount of DKFH drums, Kontakt drums, strings, rhodes, pianos and many many many tracks of audio on many ummm... creative..... clients. No issues with performance. And the drives are getting about 12-14 session hours per day at least 5 days a week.
The 3g Sata 2 drives work just fine for me in the 2008 Macpro tower.
As far as volume? Well I know its sacrilege to say it, but that volume is the least of my worries. Heaters, fans, yapping clients, and my Magma are all louder than the Mac. So how loud the drives are in comparison are irrelevant to me.
And [insert Spinal Tap accent here]... Wouldn't a louder Mac be what you want? I mean really, a louder Mac means we have to turn it up louder to mix... giving us a louder mix... what we've always wanted all along... Louder is ALWAYS better [/accent]
Seriously though, over any other drives, I don't think the noise would be much of a factor. As far as heat, the Caviars seem to run cooler than my old Hitachi 2tb models.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 12-15-2010, 01:26 AM
WOW, great write up!
From this link on page two, do know which of the 2 TB it was?:
http://www.wdc.com/wdproducts/librar...879-701276.pdf
MBP internal hard drive irwinmfletcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 12-06-2009 09:32 AM
Internal Hard Drive Drumman082 Pro Tools TDM Systems (Mac) 4 05-06-2008 07:15 PM
Internal hard drive/Mac Pro sellinout Storage Subsystems 0 02-03-2007 05:05 PM
Can I mix using my internal Hard Drive?????? Gibsonexpl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-28-2005 11:47 AM
002 Internal Hard Drive groovilini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-30-2004 11:45 AM
