audio clock error
Hello. New Pro tools user, bought a new laptop I thought could handle it...see Sandra below.
Installed normally, everything worked right by the manual...until I pressed play. I cannot do any playback at all; the error " Problem detected with audio clock. Please check that your clock source and sample rate are correct" comes up. Of course I went into setup and made sure the sample rate is correct, and it is (44.1). The audio clock is set to internal, as it should be. But I cannot get playback still. Have been reading posts on this forum about this topic for days now, and everyone with this problem seems to have a hard time troubleshooting it. Poeple seem to suggest not saving to a system drive, (which I was trying to do, and will buy an external drive tomorrow) but most threads go on to say that didn't work. It seems to be a compatibility issue, maybe with windows 7? Maybe it's something with the built-in audio cards that 's incompatible, and I gotta disable? Anything helps!! Sandra: SiSoftware Sandra Computer Model : Lenovo 4313CTO Processor Model : Intel(R) Core(TM) i7 CPU M 620 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 4 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Lenovo 4313CTO BIOS : Lenovo 6MET64WW (1.27 ) 07/15/2010 Bus(es) : PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 7.87GB DDR3 SO-DIMM Chipset Model : Lenovo Core (Auburndale/Havendale) DRAM Controller Front Side Bus Speed : 1x 133MHz (133MHz) Total Memory : 8GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Samsung M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Samsung M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module Memory Module Video System Video Adapter : NVIDIA NVS 3100M (16 SM4.1, 512MB DDR3, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : NVIDIA NVS 3100M (16SP, 474.3MB) Storage Devices Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (Q:) Logical Storage Devices SYSTEM_DRV : 1GB (NTFS) Windows7_OS (C:) : 455GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) Lenovo_Recovery (Q:) : 10GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) Peripherals LPC Hub Controller 1 : Lenovo QM57 LPC Interface Controller Audio Device : Lenovo P55/PM55/3400 High Definition Audio Audio Codec : Conexant 5069h Audio Device : Lenovo High Definition Audio Controller Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Serial Port(s) : 2 Disk Controller : Lenovo P55/PM55/3400 6 port SATA AHCI Controller Disk Controller : Lenovo PCIe SD/MMC Host Controller USB Controller 1 : Lenovo P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Lenovo P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Lenovo E832h SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) 82577LM Gigabit Network Connection Wireless Adapter 1 : Intel(R) WiFi Link 1000 BGN (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 25% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 |
Re: audio clock error
a little more info for you helpers:
To be clear: I get no playback at all. I cannot play the PT demo session. I cannot play a click track. I cannot do anything that involves playing/listening/recording etc. The basics. It seems like other people that had this problem had unsupported processors (For example, Turion). Is mine unsupported? How do I check on this? |
Have you disabled the wireless when running PT? Which version of PT? Which interface? Where is your separate recording drive?
Wireless is Disabled... Pro tools version 8.0.3. Am gonna upgrade to 8.0.4 tonite. Was not runnng a separate drive but just bought a WD black, will install and get back after making those changes.
And Mbox 2
I had the same problem with pretty much the same setup, it really had me pulling my hair out. I just got off the phone with Digi (they'll always be Digi to me) and was told Windows update 8.0.4 adresses compatability issues with Win 7 and should solve our problem.
look for it here onder the "what's hot" header: http://avid.custkb.com/avid/app/self...ommunity3=1450 It's a 780 meg download so it's going to take a while. If it doesn't work I will post here again. |
Was this issue ever solved? I just posted a similar thread as I have been unable to get any audio from my new laptop!
If you did work out how to fix this i would be most greatful as it is sooooooooooo frustrating (as I am sure you know!) |
Audio clock error | VicBanger | Windows | 9 | 04-13-2013 02:12 PM |
Audio Clock error ... ? | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-15-2012 01:29 PM |
Audio Clock Error | mongrel8686 | Windows | 9 | 05-07-2012 08:30 PM |
Mac/ 10.5.8 Audio Clock Error | glenbird | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 08-25-2010 09:34 AM |
Error: "Problem detected with audio clock. Check that your clock source and sample... | mongo_man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 05-01-2010 06:08 AM |
