Old 09-28-2010, 07:14 AM
colinato colinato is offline
Default Multiple bit depths in same AAF/OMF
I just received an AAF with bit depths listed as 16, 24. Will Protools convert everything to my session bit depth? Is there any potential issues? Everything so far sounds fine, but I don't want to get half way into it and realize there's a problem.
I vaguely recall seeing a thread about this in the past but can't find it.
Any help is appreciated.
Old 09-28-2010, 08:33 AM
minister's Avatar
minister minister is offline
Default Re: Multiple bit depths in same AAF/OMF
Pro Tools will convert everything to your session's bit depth. It is really not a gigantic deal one way or the other. 16-->24 won't sound better, but it won't sound worse; PT will just add 8 empty bits. If you are working at 16 and there are 24b files, PT will dither using TPDF which is pretty benign, and really hard to hear unless you are listening on an excellent system, know what you are listening for to things like long reverb tails.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
HTML code is On
different sample rates and bit depths Andres Gonzalez Tips & Tricks 4 10-23-2006 06:13 AM
mixed bit depths matt connolly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-12-2004 05:21 PM
Multiple bit depths in one session - WHEN?? John McDaniel Pro Tools TDM Systems (Mac) 4 03-13-2002 06:03 PM
SSC Bit Depths nozza1 Digidesign Hardware & Software 0 06-15-2001 02:55 PM
Multiple bit depths in PT: WHEN?? John McDaniel Tips & Tricks 7 01-31-2001 09:29 AM
