Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 05-30-2010, 03:16 PM
barismanco123 barismanco123 is offline
Default Does Pro Tools have a frequency response?
Hi all,
Just a general interest question that I can't seem to find the answer to. I don't need to know but would like to.
Forget about word clocks, microphones, monitors and all other gear which would have their maximum and minimum capabilities.
I want to know what is the lowest frequency that Pro Tools will play back and the highest it will play back? Can it play back frequencies higher and lower than the human threshold.
I was just thinking about harmonics etc and that they can exist way higher and lower than we hear.
Thanks
PTLE8 with an Mbox 2, for now!
Old 05-30-2010, 04:33 PM
netnoggin netnoggin is offline
Default Re: Does Pro Tools have a frequency response?
Originally Posted by barismanco123 View Post
Hi all,
Thanks
You mean Pro Tools the software, or are you talking about your (yet unspecified) Pro Tools/Avid audio interface? Which one do you have? The interface will be the limiting factor, although you are correct that Avid is not exactly forthcoming about things like frequency response. On their spec sheets they usually show only flatness within the 20-20khz band (+/- 0.25db for the MBox 2 for instance.
NN, aka Hobonoggin
H.I.T. Program graduate (Hobo Internship Training)
Old 05-30-2010, 04:37 PM
Hi netnoggin,
Just the software, not hardware related.
Thanks
Old 05-30-2010, 04:48 PM
Well, it's kind of irrelevant, since you are tied to the hardware to make anything audible happen, but...
I don't know the actual answer, but here's some food for thought. Pro Tools will easily display any DC offset on your incoming signal, which means it goes to DC (or 0) on the low end. On the high end, the HD version of Pro Tools is capable of recording at 192khz, which implies an upper end of something around half that, if Harry Nyquist has anything to say about it.
But again this is all theoretical, as your limitation is the audio interface itself.
NN, aka Hobonoggin
Old 05-30-2010, 04:56 PM
What if I downloaded a wave file of a recording of a low frequency noise capured on a scientific microphone, say of an under water soundwave. I am not tied to my hardware as I dragged and dropped it in, for example.
What would Pro Tools do with that sound, would it show on the meters even? Imagine the soundwave did not have harmonics that even hit 20 Hz so it was inaudible to humans.
I guess one thing would be to try it, but I'm just curious at this stage and wondered if it was a well known thing but maybe it's not...
Sorry for the silly questions, I'm just curious.
One of the programmers must know...DTS?
Old 05-30-2010, 05:03 PM
As I mentioned in the previous post, Pro Tools does indeed go down to 0 (zero, as in DC), so your underwater soundwave scenario won't be a problem. Zero is much lower than 20.
BTW, they're not silly questions, at least not to me.
NN, aka Hobonoggin
Old 05-30-2010, 05:04 PM
You have a signal generator in pt. Instead of asking, go find out!!!!
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 05-30-2010, 05:06 PM
Someone still needs to answer some technical questions though. For instance, DC doesn't show up on the level meters, I don't think. So that implies there is some sort of defined low-end for the meters anyway other than zero. But the waveform should be accurate.
NN, aka Hobonoggin
Old 05-30-2010, 05:09 PM
Well if I cant be a PT nerd here then it's nowhere I guess
I will, though I did think the lowest it went was 20Hz.
It does make me wonder still if there is an absolute lowest and highest. I suppose only the programmers know this.
Cheers
Old 05-30-2010, 05:11 PM
I think that too.
Do people use PT for science, if not it may be for the inaccuracy as non human threshold frequencies?
What can I do about my bad frequency response? shanemorales General Discussion 11 09-24-2013 07:48 PM
Is there anyway to test my CR frequency response in PT? Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 29 03-07-2010 01:54 AM
Interface frequency response jahhn Pro Tools TDM Systems (Mac) 0 01-11-2008 12:09 PM
test frequency response StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-02-2003 01:19 AM
Frequency response of 192 uno1234 Pro Tools TDM Systems (Mac) 4 03-01-2002 12:10 AM
