Viewing channels of a "Multi-Mono" plugin simultaneously
How do you see multiple channels of a Multi-mono plugin simultaneously? for example, I'd like to see the Left, Right and Center channels of a multi-mono plugin on a surround channel at the same time.
Tim |
Disregard. I figured it out.
Press alt and click on the L button (next to the stereo link button)
Alt, what is this that you speak of.....
My qwerty is the 2008 model from 8-core harpertown and it has Alt printed on it!
You still have the old qwerty Is it technically OPT on a mac? why has mine got Alt printed on it?
Can you have "center" as default view with multi mono plug in? | dgoodi22 | macOS | 4 | 02-08-2013 12:41 PM |
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track | rockguitarist1255 | Pro Tools 10 | 4 | 12-07-2012 08:07 AM |
Viewing center by default on multi mono instances of 5.1? | cocamycola89 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 10-11-2012 02:19 AM |
Slip mode - viewing what's "underneath" a pasted region | nhwinni | Pro Tools 9 | 2 | 09-08-2011 07:10 PM |
What do i import a "dual mono" audio file as??? mono or split stereo? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-17-2002 04:02 AM |
