Old 06-03-2008, 11:48 PM
soundonsound soundonsound is offline
Default Routing out Logic 1 & 3, anyone know basic Logic routing?
I'd post on apple forums but I know you guys are smart and some use Logic..
So in Pro Tools it's as easy and configuring the IO Setup output tab to out 1 & 3 for the C24 to play a normal stereo output (since the dsub is wired for 5.1 by default)
I'm new to Logic and monitoring via my C24 and basically need to know how can I switch all the outputs for logic to go out 1 & 3, instead of 1 &2?
I'm use TDM with my HD3 for playback so Digi Core Audio pref isn't the answer.
I see you can open the Digi hardware setup in Logic, but I need the IO setup I think. Any ideas? Maybe I'm totally missing something.
Old 06-04-2008, 04:33 AM
C C is offline
Default Re: Routing out Logic 1 & 3, anyone know basic Logic routing
In Logic 7 and below it was done from the Audio Configuration Window, but I can't remember (having not fully absorbed) where you do it in version 8.
C
ps/ logic manual on the apple site should be able to tell you (try page 812)
www.apple.com/support/logicpro
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 06-04-2008, 10:42 PM
Thank you. Figured it out. I needed to setup 2 seperate aux tracks with 1 using ESB 1 IN going out 1/2. and second aux with ESB 2 coming in and going out 3/4. and now I'm hearing stereo tonight.
Basic Midi routing in protools Please:( Flyingonempty MIDI 9 10-05-2011 01:54 AM
basic midi routing for dumb newbies wschuchner MIDI 3 12-31-2009 08:48 PM
basic routing question charlie_m 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-21-2007 08:05 PM
Basic Midi Routing Question dawtx MIDI 1 09-29-2006 10:05 AM
digi 002r/logic pro6.4 routing querie grymes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-14-2005 10:11 AM
