moving phrases
i need to edit my drum tracks by moving single snare hits and also rev cymbals.i cant get the idea from the ignite book i have(all its instructions invole dragging files in but the tracks are already laid down)i know there is a way to move things slightly i just need a little help.
thanks, fenn |
Re: moving phrases
Highlight the hit you wish to move and hit Alt-H and type in the amount to move. If you are trying to tighten things up to a click, go into grid mode. Use Tab to Transient to find the leading egde of the hit>hold Shift key and drag to the right to highlight the entire hit(with decay) and seperate the region(I use cut/paste but there are other methods). Now you can drag it and it will snap to the grid, or you can cut the hit region>place your cursor near the grid and click(it will snap to grid) and paste(Ctrl-V) and it will line up perfectly with the grid. Without the grid, you will need to experiment to get hits placed right. Now if this is an acoustic kit, you may need to pay attention to leakage on other drum tracks. Remember Alt-Z to undo and once you finish, consolidate the track so it is not a boatload of little snippets. Maybe duplicate the track before you start>mute the original and have at it knowing you can delete the entire track and start again if you get too messed up with it.
Re: moving phrases
i want to be able to move stuff without snapping to grid.i tried your suggestion and it only moves the region not the audio.what do you think?
thanks,fenn |
Re: moving phrases
Highlight the hit you want to move and press Ctrl+B (or just B in shortcut mode). That makes your selection a new region. Now in Slip mode you can use your mouse to nudge or move the new region wherever you want.
Rock on. Ben |
Re: moving phrases
i think i follwed yor instructions and i still cant get it to work.i pressed ctrl+b after highlighting the region and nothing happens.im in slip mode i thought i was supposed to be.please excuse this block i seem to be having, thanks for any and all help.
Re: moving phrases
fenn
filosofem
Aaron Mulqueen - 001 HD Native |
Moving audio region without moving automation? | tokolosh | Post - Surround - Video | 6 | 04-09-2014 06:11 AM |
moving between HD and LE | mbuono | Pro Tools TDM Systems (Mac) | 1 | 09-14-2006 06:48 PM |
Recording multi-language phrases | scott waz | Pro Tools TDM Systems (Mac) | 0 | 05-31-2006 08:23 PM |
Moving from DP3 | schuey100 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2003 05:18 AM |
Moving up, but how far...? | Jessariah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-29-2001 11:52 AM |
