Old 03-19-2005, 10:38 PM
Animal Animal is offline
Default Setting up a RAID system?
001, G4 800, PTLE 6, osx
I want to set up an external RAID system, but I'm not sure what products I need. Clearly I need a pair of hard drives. But do I need a "RAID" enclosure, or a RAID controller card, or both? What about Apple's software?
Old 03-20-2005, 07:15 AM
Default Re: Setting up a RAID system?
I thought PT did not support RAID?
Old 03-22-2005, 10:22 PM
Just for backup; no recording to those disks.
Old 03-22-2005, 11:36 PM
PhiDelta308 PhiDelta308 is offline
You shouldn't need an enclosure, unless you've maxed out the expansion bays in your computer, or unless you want to do some more elaborate raid stuff (0+1, 5, etc). Most of the reviews I've read on raid products recommend using a controller card as opposed to a software raid setup, as dedicated cards tend to have better throughput. Also, there are now firewire RAID set ups you may want to investigate. From what I gather, with the firewire arrays, you get the best throughput if each drive is on a separate firewire bus.
-chris
Dual 867 MHz G4
2 Gigs RAM
Digi 002
Pro Tools LE 7.4
Event 20/20bas
bottle of Johnnie Walker Black behind right monitor
Old 03-24-2005, 09:49 AM
-chris
Chris:
Yes, my internal bays are maxed out. So you're saying that even if I'm using a pair of external firewire drives, I can do the raid with either a controller card or software, just that the controller would probably be better?
And my other option would be to get a dedicated raid firewire enclosure...in which case, would I still need a controller, or is it built in?
RAID as system disks? Jonasfp Storage Subsystems 1 12-15-2009 11:29 PM
RAID Volumes on LE System? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-20-2008 10:14 PM
RAID System Marius Eikeskog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 12-31-2004 12:16 PM
System RAID JLD Storage Subsystems 0 02-26-2002 03:15 AM
can PT Mix run on a Raid system ???? dw Tips & Tricks 6 05-31-2000 06:34 PM
