Old 03-16-2005, 02:04 PM
Animal Animal is offline
Default Can I use a MOTU I/O interface with PT?
Subject pretty much says it all.
Old 03-16-2005, 02:12 PM
leftalive leftalive is offline
Default Re: Can I use a MOTU I/O interface with PT?
Not without a digi interface as well. Don't see whay you'd want to do that though... Unless you already own one and need a lot more inputs.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 03-16-2005, 04:27 PM
cheekypaul cheekypaul is offline
I don't mean to offend, but, why are you asking that question?
How can you not know the answer?
If there is one thing that is certain about Digidesign software, it is that it will not work with any other audio interface.
i ask in all honesty.
Does their literature suggest otherwise?
Mac Computers/PT12/Lots Of Lacie D2s
Old 03-16-2005, 10:35 PM
digijohn digijohn is offline
This is an LE forum, which means there may be some non-pros in here, and it's a legit question.
Animal, the short answer to your question is "no." Only Digi interfaces with Pro Tools, and only one LE interface can be used at a time, so no Mbox with Digi 002, etc. But you *can* add more inputs through 3rd party hardware, such as a Presonus Digimax connected to a Digi 002 rack via ADAT lightpipe.
Digidesign has a proprietary attitude about their hardware. They'll tell you they don't sell audio "components," they sell "systems." I think they maintain this proprietary attitude partly because they can ensure their software and hardware work well together, and partly because they're greedy.
Hope this helps.
John
- System -
12-Core Mac Pro 5,1 3.46 GHz
128 GB RAM
Audient iD44
Pro Tools 2020
Old 03-17-2005, 01:38 PM
alance alance is offline
But motu's midi boxes will work with pt
Old 03-17-2005, 04:55 PM
shanabit shanabit is offline
Only through the Optical or SPDIF connections.
I use a MOTU 828MKII connected to my DIGI RACK 002 via the optical inputs.
Why, more inputs of course. I can leave all my synths plugged in all the time and just use the 828 to input signal into ProTools. And yes, I also use 2 MTPAV's for midi with protools. Digi doesnt care about midi at all, only their audio I/O boxes.
MacPro 8 Core,2.4, 14 Gig Ram.
OSX 10.8.2
Old 03-17-2005, 05:15 PM
lwilliam lwilliam is offline
Can you then just switch to DP or Logic and use the 828 as your primary i/o without changing any cabling?
Also, how does the 828 sound compared to the 002R?
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 03-17-2005, 05:39 PM
lwilliam: "Can you then just switch to DP or Logic and use the 828 as your primary i/o without changing any cabling?
ANSWER: Yes, and if the other synths are connected to the DIGI that you need, all you have to do is open up ProTools and create aux input tracks and route them out the Optical outs into the MOTU
ANSWER: To my ears, the 828MKII has a little more sheen in the high mids but thats about it. Pretty identical if you ask me. No audible significance.
I have OPTICAL connections in both directions so there is no changing connections at all. Sweet setup if you ask me.
OSX 10.8.2
Motu Interface RoadTech22 General Discussion 3 09-04-2012 04:15 PM
Anybody using a MOTU interface with PT 10? albee1952 Pro Tools 10 40 08-22-2012 08:08 AM
Using M-Box 2 and MOTU Interface? Chris aka Neelix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-24-2006 09:52 AM
MOTU 828 audio interface twinstickjp Digidesign Hardware & Software 2 09-20-2004 07:09 PM
Motu 828 Interface ethermion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2001 08:22 AM
