Old 08-15-2004, 01:34 AM
instro001 instro001 is offline
Default *HARD DRIVE QUESTIONS!*
Wassup people.. recently i purchased a 160gb hard drive to use as a secondary hard drive dedicated to recording and storing pro tools data.. Now the questions are .. is it legit to run pro tools from the primary drive and record into the slave drive.. or is legit to run pro tools and record altogether within the slave drive..?
Old 08-15-2004, 02:34 AM
Bastiaan Bastiaan is offline
Default Re: *HARD DRIVE QUESTIONS!*
Both are legit, but the best thing to do is to install protools itself on the same drive as your windows, and then all the sessions on the other drive. That way the load gets spread quite evenly
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 08-15-2004, 09:35 AM
cruisemates cruisemates is offline
Sorry... but it always gets my hackles up when someone says "slave" drive because that implies you are using two drives on the same cable in a master/slave config.
I really don't think you should do that, because that puts both drives on the same controller and doesn't accomplish the whole point of having separate drives for system and data.
The drives should be drive 1 and drive 2, both connected to the computer by separate cables (whether internally or firewire).
- but the second mouse gets the cheese
Old 08-15-2004, 11:50 AM
jazzmandan jazzmandan is offline
I just installed a new 120 GB drive and it recommended not a Master / Slave dip-switch setting but rather a Cable Selected setting. Does this make sense..
Dan
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox
09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox
10/31/2009 - Win 7 64Bit
MBox /PT not supported under Win7 - I didn't leave PT, PT left me!
11/30/2009 - MBox, REAPER
http://www.jazzmandan.com
Old 08-15-2004, 12:12 PM
CozmoXP CozmoXP is offline
You are much better off connecting the 2nd drive to your other ide channel on its own cable. cable select just attempts to make it so you don't have to mess with jumpers, but still won't solve the problem of the drives having to share bandwidth if they're connected to the same wire.
AthlonXP 2700+, 1.5GB XMS DDR,A7N8X Dlx,120g 8mb Seagate System drive, 160g 8mb SATA recording drive, dual 19" CRTs and an 002r on XPSP2!
Old 08-15-2004, 12:15 PM
so its best to keep them seperate cable wise.. so what if i do this. purchase one of them ide pci cards .. and hook up the second hard drive with a seperate cable on to there..?
Old 08-15-2004, 01:53 PM
Matt Whritenour Matt Whritenour is offline
speaking of master and slave arn't harddrive companies not allowed to use the terms master and
slave on there drives anymore?
www.klarityrecordingstudios.com
Old 08-15-2004, 02:05 PM
So I set up both my internal hard drives as "cable select" instead of moving the dip suitches to Master and Slave. Although everything booted nicely, PT LE did not seem to like it when I put the Program files on the Master ("System Drive") and the Audio files on the "Second Drive". I would get an immediate 90xx Error when I tried to run a session.
So, based on the comments above, I opened open the case and set the dip switches to Master (for the System Drive) and Slave for the Audio Drive. I had to keep the internal cabeling exactly the same since there was no option to hook a second drive cable to the motherboard of my Dell 4600.
Every thing boots well... now I will check PT?? stay tuned..
Maybe I am not getting it?? Do I need to add a "card" to connect the second drive??
dan
Old 08-15-2004, 03:57 PM
well what i'm saying is that should i purchase an ata133 controller card(not ide correction on that)
in order to run both drives. Connect Master Drive with its own cable to ata133 card along with the Secondary drive with its own cable to ata133 card. Does that make sense? and to Jazzmadan .. your saying its better to run 2 hard drives all on one cable as master and slave..?
Old 08-15-2004, 06:06 PM
I have to question this though I am not a computer genius. I understand the logic but, what happens when you add CD-RW and DVD-RW drives as I have. If I put a CD-RW drive on the same cable and it is only capable of DMA 2, will it drag the attached hard drive to DMA 2 as well? AT present, I have 2 hard drives on IDE channel 1(operating at DMA 5) and my CD and DVD burners on IDE channel 2 (operating at DMA 2). Just looking for more education on this.
G5 + hard drive questions GSM79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-02-2004 04:11 AM
hard drive questions....again nightshadecrisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2004 10:38 PM
Hard Drive Questions blameus_product 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-06-2003 05:11 PM
G4 Hard Drive Questions lexusboy General Discussion 2 09-15-2002 08:18 PM
Hard drive questions Niklas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-30-2002 03:33 AM
