Old 08-13-2004, 12:44 PM
Animal Animal is offline
Default Outboard FX not printing with the Bounce to Disk!?
I'm routing an Aux channel with an I/O to a hardward reverb. I can hear it in the mix when I play the track in the PT session file. But the 'verb isn't printing when I bounce the songs. What's up with that? The PTLE reference guide says it SHOULD print....I can't figure out why it wouldn't.
Can anybody help?
Old 08-13-2004, 02:09 PM
ghoti ghoti is offline
Default Re: Outboard FX not printing with the Bounce to Disk!?
Greetings,
Check to see if Low Latency Monitoring is selected. This will prevent outboard effects from printing.
Hope this helps.
Peace,
ghoti
Old 02-25-2005, 04:59 PM
Oh, sorry, meant to add that Low Latency Monitoring is OFF and the buffer is set to 256. I was reading through the manual and is says the buffer should be as high as possible, but I though high buffer setting on mix down = extreme latency in I/O.
I'm sure some of you mix with outboard gear. Any suggestion?
Thanks.
Old 02-26-2005, 02:56 AM
shanabit shanabit is offline
Bump, I need to know this as well
MacPro 8 Core,2.4, 14 Gig Ram.
OSX 10.8.2
Old 02-26-2005, 09:27 AM
OK, I got it working! I changed my buffer size to 512 and it works. At hight buffer settings there was a HUGE latency problem and at lower setting it wouldn't pass audio, but 512 seems to be just right. Weird.
D
ADC and printing with outboard Gear- Help! jamieboss1 Pro Tools TDM Systems (Mac) 3 02-14-2007 05:10 AM
Bounce to disk vs. printing to track mr.armadillo Post - Surround - Video 4 06-15-2006 09:07 AM
Outboard CD-R (bounce to disk is weak!) G.roots 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-20-2002 10:32 AM
bounce to disk with outboard gear help !!! shortbus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2001 08:32 AM
Outboard effects don't bounce to disk? Kerry C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-08-2000 12:54 AM
