#21
Re: Adapter cards by PCI-X PCI-e! Does it work?
Warning: brown-socks geekery ahead.
There are almost no MoBos for dual-processors on PC anymore, because people who build performance computers have understood the dual-processor thing is now almost useless, we have cores now. Apple keeps pushing it because it's been one of their selling points since the G4. And that was because they couldn't push the PowerPC processors because of poor temperature and power efficiency so had to split the work. In practice in Windows-land, dual-CPU systems mostly just cost more money. As for PCI slots, off the top of my head I can name one LGA1156-based motherboard that has three PCI slots along with PCIe slots. Granted, that is as much a measure of how much I don't have a life as one of how readily available they are. Things have moved along quite a bit since the time when many people seem to have formed their opinions on computer systems and OS's. The Windows machine as a music machine is not as daft anymore as many seem to think. |
#22
But most confusing part was processor side. I see people talking about i7's but in fact there is like 10 of these starting from $300 to like $1300 and for me it is pretty hard to tell the difference as per ghz they are "about the same" Would appreciate some information about this if someone knows better. Motherboards I found with 4 PCI slots were these: Gigabyte GA-P55-US3L Intel H55 Express 1156 Motherboard Gigabyte GA-P55-UD3L V2.0 - Socket 1156 - Chipset P55 - ATX EDIT: more boards with 4 PCI Gigabyte GA-P55-S3 |
#23
Well I use a P6t WS pro with a Magma p7r464 chassis to hold my HD 4. The chassis is an old pcix to pcix but they still work on PCI slots. Always have. Just not PCIe slots. Also, be careful of using desktop motherboards for PT HD. Might be fine for native but I wouldn't chance it with HD. Use a workstation board.
Best |
#24
Yes, if you follow the link on the Air Users Blog it takes you to ASIO4ALL. I didn't go beyond that. It's not officially supported, but he's saying in his blog that users are having success aggregating devices. He indicates it might not work with every audio interface out there.
#25
Thanks in advance. |
#26
Any compatibility issues in terms of RTAS and TDM plugins running Windows 7? Will I lose plugins switching platforms?
#27
Yes correct. I say it again. The PCI-X pro tools cards are actually PCI cards but with a physical PCI-X form factor. Compatible with both PCI and PCI-x slots.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
#28
So all I have to do is isolate those unused lanes so they are not exposed to short-circuit or something like that. You have not idea what a great news you gave me! |
#29
Don't know about the GA-P55-S3, but the other 2 mobos you listed are going to be pretty hard (read: fuggedaboudit !) to find. They've been d/c'd for a while. The mobo in my sig is NOT a workstation mobo, but it has 3 adjacent pci slots (read: HD3) and works great. I've put 3 months now of work on it with no probs running win7 64... First stable PT sys I've had in over a year... AND, best of all, you can still purchase it ! Newegg/Microcenter/etc... It runs about $110... Re: various i7's: I didn't want to overclock our TDM rig, so I didn't even consider the "extreme edition" models. I run an i7 870 (cost like $200) and it's PLENTY FAST on our machine with an HD3accel rig (compared to my former PPC G5 2.7). The mobo/socket (for Intel your options are 1156 and 1366) and chipset (H55, P55, yada...) will determine specifically which processors you CAN use, so it narrows down a bit once you pick your mobo. If you're planning on using PCI or PCI-X cards, then you need PCI slots. Those seem easier to find on the 1156 socket mobos... and if you need HD3 or HD4, it REALLY narrows your choices down. Again, I couldn't be more pleased with our system. Lastly, a few guys have been posting Q's about the PCI-X cards in PCI slots. As someone already posted, the digi PCI-X cards ARE PCI cards FUNCTIONALLY, but the physical form has that extra bottom "male socket tab". It's ONLY a problem if the mobo you purchase has a "tall" structural component just behind the PCI slot. (most often i've seen heat sinks). The board in my sig. does not have this issue, btw. The UD3L you mentioned above DOES, but hey! that's why Dremel Tools were invented !!! Anyhoo... I hope I'm not coming across as any kind of "expert" here, I'm certainly NOT. But I did make this jump recently, and had to go to WAAAYYY too much trouble to find the info. I don't see ANY reason why that should continue. The guys over on the Win TDM forum are real helpful (Brandonx1 is one of them), you guys should have this discussion over there... Hope something here helps...
-C' ya' Rick MacPro 7,1; 16 core OSX 13.5.2 PT 2023.9; Eucon 2023.6 Dock/S1/2x iPad |
#30
Thanks Docric; I bookmarked your post just for your sig.
does this adapter work? | matias4000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2011 06:05 PM |
Will 002 work with g4Port serial adapter in OS9? | JoeM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-08-2010 12:50 AM |
FXpansions VST-RTAS adapter - does it work? | jobijam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-18-2005 09:26 AM |
Does the UAD card w/VST to RTAS adapter work well? | Imagine | Pro Tools TDM Systems (Mac) | 2 | 07-16-2004 07:33 AM |
So does the VST/RTAS adapter work? | medievil | Tips & Tricks | 4 | 02-25-2004 02:45 AM |
