Can't record at a low buffer !!!!! Help !!
Mac Pro 2010, 12 core 128 gigs of ram. All SSD Drives. Sierra V 10.12.6
Graphics card Sapphire HD 7950 4k. Can't record at buffer of under 128. Even when I have no plugins in the session. Just a stereo music track and 1 vocal track. I get an immediate CPU error. Reason I'm asking is I can't send sep lines out of analog outs to a headphone system without latency. I need to be able to set the buffer to 64 in order to get no latency on the vocal in the headphones. Last edited by Barry Weeks; 11-17-2017 at 12:45 PM. |
Re: Can't record at a low buffer !!!!! Help !!
Please follow the DUC terms of use and make one post per problem. I'll delete my reply to your other post.
What buffer size? 2128 is not a valid size.
But if you mean 2048 or 1024 or similar... Something is plain broken here, you need to go though the normal trouble shooting steps under "help us help you" up the top of every DUC web page. Especially: trash prefs, move all plugin files out of the plugin folder and restart (yes even if you are not using any plugins), trash prefs again, try using something else as the playback engine, anything e.g. an aggregate of line in and built-in output, start from a new empty session, repeat tests from a newly created admin account, uninstall and reinstall Pro Tools..... and start by making sure the system is *fully* optimized, every last thing done. Make sure ignore errors is not checked (you want to see all errors while debugging), and while there make sure dynamic plugin processing is also not checked. Make sure disk cache is on, set to some value not "normal". Edit: Now I realize you probably meant 128 samples. Find the largest buffer size it does not work reliably at and go though al the above with that and see if changes improve things. If you get it stable try the next smaller buffer size. There is no *guarantee* that a system will be fully reliable at say 64 sample buffer size. You will need to work away at your system to see what you can get it down to. If you need super reliable low latency monitoring you may need to look for outboard solutions or go HDX. If you come back with more questions we need more details on what you are using, interface and driver version, more details on the Mac, etc. Did this every behave better? When did that change? (e.g. upgrade from Pro Tools 11 or previous version of 12?). |
Some interfaces support buffer sizes between the ones supported by Pro Tools, sometimes I get this error when using my NI KA6Try changing to 64, 128 or 256 and see what happens
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Which exact version of PT and what interface?
Darryl , thanks a million for your time in trying to help me.
I've done all of that as far as trashing all prefs, removing all plugins, however I just tried a different playback engine and problem solved. However, ha I must use the HD playback engine in order to use my hardware. Any thoughts? Also, as far as I'm aware I gave you all the stats on my computer. If I left some out please advice. |
cheers john
Protools aggregate.
oh .. using what as IN's and OUt's ... ???
the sound of the Dentist Pulling Teeth !!
Record Buffer | SPC | Pro Tools TDM Systems (Mac) | 1 | 07-05-2005 08:34 PM |
cant record at lower than 256 buffer | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-09-2005 05:57 PM |
Digi 002 can't record at 128 Buffer?? | Third Eye Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-17-2004 07:09 PM |
what it's like to record without buffer errors? | marc_c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 07-18-2004 05:03 PM |
Record Buffer Problems | strumbacler | Digidesign Hardware & Software | 0 | 12-19-2000 07:42 AM |
