Old 02-13-2014, 11:54 AM
ducada ducada is offline
Default Digital Performer 5 files
I have a client who brought 3 sessions he needs to tweak. He fails to tell me that these sessions were done years ago in DP 5. No one I know has this software and the latest version of Digital performer cannot read the files either. I'm using MAC OS. Any one has any suggestions?
Old 02-13-2014, 12:18 PM
C C is offline
Default Re: Digital Performer 5 files
digital performer forum and ask for an omf export from someone with v5?
Proconvert was other thought but it doesn't seem to deal with DP at all.
Good luck.
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 02-13-2014, 12:42 PM
Phil Ogden Phil Ogden is offline
They could be SDII files? If so, older PT rigs might be able to read them.
Old 02-13-2014, 12:43 PM
did that days ago. no responses. any other suggestions?
Old 02-13-2014, 01:35 PM
ChuckS ChuckS is offline
What did he bring them to you on? If it was a thumb drive or any other media formatted for a PC you won't be able to access them. If he still has his Mac with DP5, tell him to zip the sessions and then you'll be able to import the audio files when you unzip or the current version of DP on the Mac will open the session file.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-13-2014, 02:08 PM
I can see the files. They are just unrecognizable
Duncan "Ducada" Forbes
Head Engineer/Producer
Ducada Entertainment
Brooklyn, NY
P: 347-260-2621
E: [email protected]
Old 02-13-2014, 02:18 PM
If they have the unix exec icon then that's the problem - the file resource forks have been stripped. Zipping the session folder on the original Mac for transfers preserves the resource forks.
Old 02-13-2014, 02:20 PM
The original mac it was recorded on is no where to be found
Brooklyn, NY
P: 347-260-2621
Old 02-13-2014, 02:24 PM
C C is offline
do the files have extensions on them? if not could it be that adding an extension to the filename might enable DP8 to see the file? installed DP8 demo to see if I could see any clues and in the manual it lists that it can export to DP 3.1 upwards and import from "Files created in earlier versions of Digital Performer and Performer"
Don't use DP so have no real life experience with it, just spitballing.
C
Ceri Thomas
Personal Site
Old 02-13-2014, 02:41 PM
C
You can try adding .dpdoc to the session file and .aiff or .aif to the audio files, but if the audio files are SDII that won't work. If you want to recover SDII files, Google Soundhack. It will let you rewrite the headers for raw audio files.
do I have Digital Performer files or not? c-post Pro Tools TDM Systems (Mac) 1 09-27-2006 10:39 AM
Can Digital Performer read pt 5 files? BLUEMAZE.COM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-12-2003 07:44 PM
OMF Files Digital Performer rseely 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2002 10:45 AM
Opening up files in Digital Performer Mr. Nizzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-29-2001 08:30 AM
Export Digital performer 2.7 files to PT 5.1 Loops Pro Tools TDM Systems (Mac) 2 07-05-2001 07:00 AM
