Having problems with my H/W Buffer size
Hello,
I am Running Pro-Tools 7.3 on a Mac G5 2.0 Dual Processor with 1GB Ram. I record interviews and sermons that range in size from about 30 mins-1 hr but after about 7 mins. or so it stops recording. What can I do to correct this problem. The Error code is H/W Buffer size Playback engine Panel 6086 Thanks The Poet |
Re: Having problems with my H/W Buffer size
Are you recording to the system drive or to an external firewire hard drive?
Are you using the 002? If you are, then to what port is it connected to?
PPC G5 Dual 2.0, 8.5G Ram PT 8 cs2 OSX 10.5.8 MBP Core 2 Duo 2.16, 2G Ram PT 8 cs2 OSX 10.5.8 Mbox 2 Pro, Mini, Micro |
I am recording straight to the system drive!
and yes I am using the 002 going to the back firewire port. Are you saying I at least need 4.5 GB of Ram? |
I just hooked up my 003 console and I was getting the same error -6086 and -6093. What I did was trash the digidesign data folders on all my hard drives and made sure my P.T.L.E. system was up to date (latest versions for OSX) and re-started and it's ran perfect since. Error messages have disappeared.
GORILLA
METAL LABS |
did you change (in prefferences) the maximun time of the Session?
is allways stoping after 7 minutes?
Powerbook 12" 1,5Ghz 1,25Gb RAM M-Box v.1.0 "the old one" PTLE 7.0 Tiger(10.4.6) Ministack v2 NEWERTECH FIREWIRE+SEAGATE 320Gb |
Update to 7.3.1cs2.
1 Gig of RAM is marginal. I recommend two. Do not use your system drive for audio. Digi does not support that. Get a Firewire drive.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Thanks I will try all of the suggestions. I did buy 1 more GB of Ram today. but what type of firewire drive would you suggest? and are you saying that I sould not record my musice to the Mac's Hard drive?
Poet |
If you are not using a MBox Pro 2 then buy FW 800 drives. If you are then buy FW400 drives.
Other World Computing is one good provider. piece
MacBook Pro DuoCore 17" 2.16Ghz • OSX 10.4.9 •*2Gb RAM • MBox 2 Pro • ProTools 7.3.1cs3 • FW 800 w/ Express Card |
Yes, you should not record to your Mac system drive.
It is not supported. You will need a firewire external hard drive. I use OWC's Mercury Elite. Other popular brands are Lacie and Glyph. Hope that helps.
Thanks a lot. I will get an external drive. So do I need to set up something special to record and save, or do I just record all of my sessions straight to the external drive?
And Yes it helped a lot I appreciate all of your help |
Buffer size problems(too little then too much) during recording | nathanh26 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-02-2009 09:19 AM |
H/W Buffer Size Problems | soulcatcher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 12-19-2006 04:11 AM |
"H/W buffer size" pop-up problems | mickj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-15-2004 08:39 AM |
H/W Buffer size problems... | Stingray74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-24-2004 01:06 AM |
BUFFER SIZE PROBLEMS... | Renan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-04-2004 01:32 PM |
