Multiple Rewire apps in addition to Reason
Can you run 2 rewire apps at the same time in pt??? Such as recycle and reason???
Simple question, simple answer. Thanks in advanced Christian |
Re: Multiple Rewire apps in addition to Reason
Yes. I run Reason and Live into PT. Not sure if Recycle is a ReWire app though.
SHan
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Do you mean two separate reason outputs rewired to two input tracks in PT? Or do you mean receiving just a stereo rewire from reason to PT? I have only had reason 2.5 for a week, so I am a newbieeee ; however reading over the "getting started" manaual yesterday, you can run as many rewire reason to PT inputs as you have sound cards.
In the case of how many reason sequencers you can rewire over, it depends on how much CPU you have. Could be wrong, I don't have the manaual in front of me at the moment, just java...
Kevin 002 XP2700 A7N8X 1g ram; 20/80 WD |
Rewire apps not showing up. Help | toddm7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-08-2007 05:09 AM |
Recommended plugins/rewire apps | davetheone | Tips & Tricks | 0 | 11-23-2005 10:40 PM |
Recommended Plugins/Rewire Apps | davetheone | ProControl, Control|24, Command|8 | 1 | 11-22-2005 12:54 PM |
DP and Rewire Apps-Do we know for certain..... | LurkerAtTheThreshold | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-14-2004 09:09 PM |
Reason rewire multiple stereo outputs possible? | sinawava | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-07-2004 05:41 PM |
