PT extremly slow with enabled network-connection
Hello everybody,
I have a big problem with my Pro Tools 2020.9 installation on my Windows 10 system (Version 2004, build 18041.508). It only works when the network connection is disabled. If it is activated, it takes a very long time to start the program. When pro tools has started the program works extremely slow. When disabling the network adapter pro tools works fine. Unfortunately, sometimes I must have the network connection to do recordinmgs via session link with other studios. Do you have an idea how I can fix this problem? A few months ago, it worked fine when the network connection was enabled. So I think it has something to do with a Windows update. But unfortunately I haven't found any solution to the problem in various forums so far. Does anyone made similar experiences? Thanks in advance and greets from germany Martin |
Re: PT extremly slow with enabled network-connection
I have un-installed OneDrive here, and live happily ever after. Still on 1903 here, and plan to upgrade to 2020.9 / 2004, so pls report how things proceed for you. /FZZ |
I've had similar issues with OneDrive and have it disabled on my PT computer. Since PT stores info in your Documents folder, it is always syncing in OneDrive and this can slow things down.
Take a look at this Microsoft article on how to change your OneDrive settings or remove it all together. It's worth disabling it to see if your problem goes away. |
I uninstalled OneDrive but it did'nt fix the problem.
Again I checked the PT Troubleshooting advices. One point I did'nt trie was "Create a new user account". I did so and created this new user account and it seems that there are no problems with network and PT. So I conclude: 1.) there is no hardware problem (e.g. with networkadapter or it's driver) 2.) the problem is my current (old) user account So far, so good. Now I have to find out what's wrong with my current user. I fear to setup everything in the new account. |
"Last year, Microsoft promoted the use of Windows 10 online accounts to some users in the United States. It is not easy to find local account options when users install the system. Microsoft does not completely prevent users from using local accounts but hides its options. If users do not carefully observe the installation interface, it will be difficult to find this option. The reason why Microsoft requires users to use online accounts is actually very simple. Online accounts can provide more cross-platform functions and collect more data from users. With a local account, Microsoft cannot capture and upload a lot of private information." Found it here: https://meterpreter.org/microsoft-co...-installation/ /FZZ |
Very interesting information. However, my current user is set to "local" - or let's say: I think so. But maybe there are some hidden options which have to be found, but where? I'll have to look around at google... For the moment I decide to use the new account for working with PT. Thanks, Martin |
Looks like P.T. trying so connect with smth,but do not able to.
In my opinion it`s a bug.Or internet issue |
I may have found a new clue to the problem. There is another pc in my network which is rarely switched on. I have connected it as a network drive on my PT computer. By chance the second pc was switched on yesterday and it's network drive was available. From this moment on PT started without problems. Now i wonder why PT has problems if this network drive is not available? More network drives are connected from a NAS server. If they are'nt available (NAS-server switched off), there are no problems with starting PT. Only when the second pc is turned off does it seem to have these problems. I don't know, what PT is searching on this network drive? Greets, Martin |
MCPro losing network connection | blob | System 5 | 0 | 04-26-2019 12:07 AM |
S6 Lost Network Connection | youngas75 | Avid S4/S6 | 7 | 12-12-2017 10:36 AM |
EXTREMLY SLOW download speed with Avid Application Manager | Alexound | Pro Tools 12 | 2 | 01-10-2016 07:35 PM |
Icon Locks up on Network connection | roberts | ICON & C|24 | 0 | 04-25-2012 10:52 PM |
Structure 1.1, extremly slow database rebuild | tonwurm | Virtual Instruments | 8 | 08-29-2010 07:26 PM |
