FS: Euphonix MC Pro
Euphonix MC Pro
Asking price : €6.000, located in Amsterdam, Netherlands In my opinion the one and only controller for your DAW. Originally (and still) priced as a €25K controller, this beast seems to be a very serious, robust and stable machine and never let me down. You can fully organize it yourself by programming your own editing structure in the 65(!) soft keys, and/or by programming keys press macros.....and of course, the 4 faders and 12 rotaries are Euphonix-quality as you'll find in the System5......built to last. The hardware functions 100% and since Avid gave new life to the OS, even the jogwheels have returned functioning properly! The specs: Touch Screen VGA Output (1024x768) Keyboard and Mouse Serial Inputs USB 1.1 100 MB Ethernet (IEEE 802.3) Connector: EtherCon RJ45 1/4" Stereo headphone in (back) pass through to out (front) 1/4" footswitch programmable from touchscreen Serial & VGA service ports Integral phantom powered electret talkback microphone 65 programmable SmartSwitches Backlight brightness controls Storage: Internal SSD USB port on the MC Pro for external USB drives Files can be stored on the host workstation Overall Size: 37.5" (952.5mm) wide, 20.7" (526mm) deep, 3.6" (91.5mm) high - 36" (914.5mm) wide without endcaps Weight 40 lbs (18.2 kg) Power: External Table Top 150 Watt PSU with On/OFF Switch DC Outputs: +5V @ 15 Amps, +12 V @ 8 Amps Input: 100 - 240 VAC 50/60 Hz Typical Power Consumption 80 Watts AC Input Connector: IEC with On/OFF Switch DC Output Connector: 12 Pin Locking Circular
Pro Tools Ultimate 2023.6 / Nuendo 12 / Logic X / WaveLab 11 MacPro 5.1: 12Core 3.46GHz Intel Xeon/ 48GB RAM/ Mac OSX 10.14 MacBook Pro: 2.9 GHz Intel Core i9/ 32 GB RAM/ Mac OSX 10.14 MetricHalo ULN8 + 2882 / RME HDSPe MadiFace Euphonix MC Pro Last edited by niekbeem; 03-06-2016 at 03:29 AM. |
Euphonix with C8 | FluffyPost | ProControl, Control|24, Command|8 | 0 | 04-05-2012 10:41 PM |
Using UAD 2 With Euphonix | gclef101 | Artist Series | 15 | 01-08-2011 12:07 AM |
PT 8.0.3 - no more Euphonix MC Mix! | JustinA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-23-2009 01:32 PM |
Euphonix MC+MIX and PT8 | manciosax | ICON & C|24 | 5 | 10-16-2008 07:47 AM |
7.4 HD and Euphonix MC Mix | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 08-26-2008 02:45 AM |
